would this cam be a good choice for a stock l98
Old Mar 1, 2011 | 12:43 AM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
well I ended up pulling my motor to clean the bay and continue on my quest to remove all the old undercoating so I figured I would upgrade alittle found this cam for sale.
227/236@.050
514/524 lift
113 LSA/
2000-5800rpm range
the motor is a stock 5.7 from a 91z Itll be paired with a t56, headers dual cats, and catback
also would like to put some 1.6 roller rockers.
Would this cam do well or would it be over kill I know I would have upgrade the valve springs. or would more be needed.
Old Mar 1, 2011 | 12:47 AM
thegooseman's Avatar
Car: 1992 RS
Re: would this cam be a good choice for a stock l98
If you get a cam like that I would upgrade the heads too. Stock heads would be restrictive with that cam.
Old Mar 1, 2011 | 05:12 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
^what he said. That cam is a good choice but not without heads, intake and exhaust work to put it to its full potential. Stock heads would not only be a bottleneck..i dont think they will handle that much lift without some work. Valvesprings are only half of it. Might need to do some machine work to get that kind of lift. And if your going to spend the money to mod the stock heads for lift...might as well take that money you were going to spend and put it towards a nice set of heads. What are you running for an intake right now? Stock TPI or aftermarket TPI? Headers are good so your exhaust is all set. Just gotta get the intake and heads flowing more and you'll be golden.
Old Mar 1, 2011 | 11:05 AM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Right now I'm just running a stock tpi setup, My plans are to go stealth or if money permits mini ram, But I'm honestly just looking for a cam that can be used on the stock heads. Nothing crazy.
I just pulled the motor and I dont see it worth it unless I do something to the motor So I figured cam and roller rockers.
Any suggestions of a cam that would fit what I'm looking for.
Old Mar 1, 2011 | 11:10 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Stock heads, TPI something in the 211-216@050 range, just under .500 lift is fine. Roller cam engine? Could find something used on Ebay just to get you by, once you swap intakes and upgrade heads you may find you want more cam especially with a stick.
Cam you listed is way too big.
Old Mar 1, 2011 | 11:32 AM
Car: 1992 RS
You can try the zz4 cam. But if you do get screw in studs.
Old Mar 1, 2011 | 12:45 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
not to mention if you're upgrading heads.. you need a way for more air to get to them.. need to think about opening up the plenum, and larger runners
Old Mar 1, 2011 | 01:18 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
yes its a roller cam engine. But with screw in studs doesnt the heads need to be removed and sent to a machine shop? the motor only has 68,000 on it..
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
anesthes
Aug 8, 2015 09:37 PM
