Wont stay running till start number 4...
Car: 1989 IROC Z
Engine: LB9 5.0, TPI
Transmission: 5 speed manual
Axle/Gears: 3.45
Hey guys been on here reading some posts and there is not one that is really discussing the issue I am having. I have an 89 vert with 305 TPI and it has been running great up till now. It starts everytime, revs to about 3000 rpm and then dies instead of dropping to idle, after 4 times of that, she starts up, drops to idle and runs great till i shut her off. Any ideas? I am thinking fuel pump, but it is not typical fuel pump problem i have dealt with. Usually in idle when you rev it would die, and she doesnt. Any help or a link to thread discussing this would be great.
Car: 1989 IROC Z
Axle/Gears: 3.45
Re: Wont stay running till start number 4...
Codes that came up:
23 - Manifold Air Temperature sensor ( this has been on for a while, i have changed it a couple times and it wont go away
34 - MAF Sensor ( replaced this a few months ago)
42 - Electronic Sparks timing
Fuel pressure is 42 lbs key on FP vacuum un hooked
Fuel pressure is 46 lbs running FP vacuum unhooked
Fuel pressure is 36 lbs running FP vacuum hooked up
The above codes in the manual all have something in common saying a defective ECM. But dont want to jump to any conclusions.
Any help appreciated.
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
however you should only do that if you have gone through all of the disgnosis to rule everything else out.
MAF code. start with the relays and check the harness and MAF connector for any burnt wires. I had a GTA that the MAF shorted and burnt the ECM ground all the way back to the ECM. not saying thats your problem just saying that it happens.
as far as MAT that is a little important so you may want to actually diagnose that because it doesn't seem to be the sensor if you have replaced it before
and 42 electronic spark timing is VERY VERY VERY IMPORTANT. that is most likely what is causing your condition. check to make sure that the brown wire on the distributor is plugged in, if it is that start at the distributor
Car: 1989 IROC Z
Axle/Gears: 3.45
Thanks guys for the input, yes i did reset and the codes are still coming up. I will look at electronic sparks control first. I might try IAC too, I havent touched that yet.
Car: 1989 IROC Z
Axle/Gears: 3.45
So I reset the codes and now the MAF sensor code comes up code 34. How do you test the MAF sensor? This may be the issue, it was part of the issue last time she wouldnt stay running
Car: 1989 IROC Z
Axle/Gears: 3.45
So now the car went from barley starting to not starting at all. I am lost on what to look into. Any help? I am getting fuel and spark, sprayed starter fluid in plenum, wont fire.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 11, 2015 10:11 PM
