its in time still backfire.
Old Apr 10, 2011 | 03:56 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
ok. so first this was first ive tried to start it. i got it all torn apart. stuck hose in no.1 cylinder till started blowing baloon up then turned it till it was on
'0' on pulley. dropped dizzy in and it pointed to no.1 pretty easily. but when i tried to start it 5seconds into turning key it backfired . so wat should i do?
Old Apr 10, 2011 | 07:22 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: its in time still backfire.
Make sure u have the wires on right, check the firing order, if thas right check timing.
Old Apr 10, 2011 | 09:05 PM
james.gould150's Avatar
Car: 1991 z28
Engine: 305 tpi
Transmission: 700r Automatic
are you positive its an ignition issue? mine would run and missfire as well as back fire...my problem was 1 clogged injector and this thing still had the factory fuel pump in the tank(20 years old yea it was barely pushing fuel to my tb) hope this helps you , but it is not a a definate resolution i only experienced similar symptoms
Old Apr 10, 2011 | 09:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Also make sure plug wires are securely on the plugs and dist cap. I had one wire that would pop itself off just enough to cause an issue - had to use needle nose pliers and bend the inner contacts on the plug end just a tad tigher so it would stay on the plug. 3 years later it's still great - just a little tweaking thing that sometimes has to be done.
Old Apr 11, 2011 | 03:51 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
these are summit wires can they be to long ? cuz they are really long.
Old Apr 11, 2011 | 11:04 AM
Car: 1992 RS
Engine: Carbed 350
Can't really be too long - too long can get annoying and "in the way", but has no effect on operation. Maybe there's a break in one, did you check continuity on them?
Are they supposed to be cut-to-fit wires and you didn't cut them?
Old Apr 12, 2011 | 12:40 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
yea but guy before me cut them ,he obviously had great worries about shrinkage.
Old Apr 12, 2011 | 06:15 AM
luvmy64's Avatar
Only thing that causes backfire (through intake) is when the plug fires and the intake valve is still open....same for exhaust (exhaust valve open)..... Check timing and work back from there....
Red iroc-z 305
Sep 30, 2015 05:22 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
