ses light supposed to flash like this at ignition?
Old Apr 14, 2011 | 11:15 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
http://www.youtube.com/watch?v=Dyoodmsbozk
its blinks like this when i turn the ignition on...
is it supposed to do this? i dont remember it doing this before and my car wont stay running..
when i put it in gear, it wants to die and it idles high in park or neutral.
been trying to figure it out here...
https://www.thirdgen.org/forums/tpi/...ll-when-4.html
Old Apr 15, 2011 | 12:00 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: ses light supposed to flash like this?
Normally the light would be on when the key is switched to the on position prior to cranking. Now once the the car turns on, it may flash and stay off. But if it stays onafter it turns on, then there is an error stored in the MemCal. Now if the light turns off while driving, then the error is intermittant, (faulty sensor that just began to work properly). Most sensors have a refference voltage of IIRC, .10 - 5.0 volts. If the voltage is out of that range, the ECM will sense it and record the troublecode to that sensor. I have a book that has a good explaination of troublecodes for the TPI if your interested. PM me.
Old Apr 15, 2011 | 12:02 PM
By the way, where in the I.E. are you from? I lived in Rialto and Hemet for a couple of years.
Old Apr 15, 2011 | 12:48 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
rancho cucamonga
thats just it though! it wont even throw the intitial code 12. its like, dead. lol..
thats why i think its the ecm...
Old Apr 15, 2011 | 12:49 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
and i know nothing about all the MemCal and PROM tuning stuff...lol
Old Apr 15, 2011 | 02:52 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
If it's flashing while the engine is running the computer is sensing that there is an issue that can cause damage to the engine or emmision control devices (most likely to cat). The flashing is to get your attention so you STOP driving the car.
Old Apr 16, 2011 | 12:36 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
it only flashes on igniton..when i start it, it goes away..
but it does the weird fan thing after i come back to it hours later after driving it before..
Old Apr 16, 2011 | 12:01 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
i think i remember it being solid before when i turned the ignition on...
dont think this is normal.
Old Apr 16, 2011 | 02:24 PM
Re: ses light supposed to flash like this at ignition?
Ill try to look for a solution in my TPI Hand book later today. I got a ton of homework to do today.
Old Apr 16, 2011 | 05:48 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
alright cool
eightsixseven
Dec 16, 2024 01:50 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
CORV3TT3
Aug 23, 2015 11:26 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
