No injector pulse
Old Jun 19, 2011 | 07:34 PM
Fiero_86's Avatar
No injector pulse
Im trying to wire up an 89 tpi ina fiero with a 355 i have spark, and the vats has been supposedly taken off the chip, but the injectors have no pulse and have voltage on both sides. Any ideas?
Old Jun 19, 2011 | 10:18 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: No injector pulse
What harness are you using? Did u check your 2 inj fuses?
Old Jun 19, 2011 | 11:21 PM
Fiero_86's Avatar
I'm using all stock harness out of an 89 firebird and I don't have fuses but there's power where the fuses should be.
Old Jun 20, 2011 | 08:25 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Check for a bad pickup coil and/or ignition module either will cause a no pulse condition.
also check the bulkhead connector on the firewall to make sure it does not need to be repinned.
Old Jun 21, 2011 | 06:09 PM
Fiero_86's Avatar
I have power to all the terminals in the ecm that i should except the check engine light and i have 5v at the vats
Old Jun 21, 2011 | 06:10 PM
Fiero_86's Avatar
And ive grounded the ones that should be grounded
Old Jun 21, 2011 | 10:32 PM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
If your sure vats was elemenated then might start with ign module it uses the ground side to pulse injectors sence you have pwer trace the ground
Old Jun 21, 2011 | 11:34 PM
Fiero_86's Avatar
Would I still have spark if I had a bad ignition module?
Because I have spark.
I have everything i need for it to run, except the injector pulse.
Old Jun 21, 2011 | 11:58 PM
camaroinoh's Avatar
Car: 84 z28
Pickup coil would be spark side for plugs so thats probly ok ign module would be pulse side for injectors i would start there check for loose connectors crimped wireing and all the basic fuses/relays ect
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
