Need Help with Idle and Engine Light
Old Sep 30, 2011 | 09:24 AM
lopezstud87's Avatar
Car: 2010 2SS/RS L99-1987 Iroc-z
Engine: 383sbc/Built 350TPI
Transmission: Built T56/700R4
Alright First i have a 1987 Camaro 350 TPI wit alil work done like a mild cam and headers..Since i have ownt he car the Service Engine light has always been on but no codes show up when i try to pull them...my problem is idle probs thought i fixed that when i replaced the TPS and IAC lastnight after seting the TPS and IAC but after 30min or so the Service Engine light will go off light its fixed but then the idle drops really low and car runs bad.but then all i have to do is turn the car off then restart it and everything is fine again untill the Service Engine light turns off and car drops idle again...when service engine is on but no codes come up just the 12 3 times and repeats...thanks for any help
Old Sep 30, 2011 | 09:35 AM
Re: Need Help with Idle and Engine Light
one more thing right before the engine light turns off the car will act like its abt to die or not getting any fuel then car runs back to normal then light goes off and idle drops
Old Sep 30, 2011 | 12:42 PM
fivestar's Avatar
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
Just wondering if you are trying to pull codes with an OBD scanner or using a paperclip to pull the codes? I had an issue with using a OBD scanner not giving me any codes but when I used the backyard mechanic way of using the paperclip to ports A & B I did get codes to come up-sorry if this seems like a silly question...
By the way for me at the time it was my MAF burnoff relay that was bad (intermittent good periods) and after spending no more than ten bucks I was good to go
Fivestar
Old Sep 30, 2011 | 01:00 PM
Fivestar
I tried both ways and still nothing but still Engine light coming on just wont go off...i unpluged my maf and it gave code 33 for it but nothing else,plugged it back in and code went away but light still on.ill try the relays...but i did noticed when i looked at my ecm connectors i had a red wire coming from the blue smaller connector that looked like it had fallen out but their are two other wires it could have came from...
Old Sep 30, 2011 | 01:13 PM
fivestar's Avatar
Engine: IROC V-8
Just recently I had trouble with my idle and the car running rough. Found no codes or even a check engine light... Thought it might be my MAF sensor since I had already changed out my in-tank fuel pump recently along with fuel filter and gas cap, I had also changed out my MAF burnoff relay as well and with each 'maintenance fix' the car ran fine...
So when the car started to run/idle rough I pulled my MAF sensor off and it idled high and check engine light came on and of course code 33. Changed out my 23 yo MAF, cleared the codes and installed new MAF sensor and viola! runs great!
It does sound like you have wiring/connection issues though, hope someone here can help you out
Old Sep 30, 2011 | 01:31 PM
Hopfuly i had a car show i was gonna go to but really dont wanna take it when the idle drops low like it does after awhile of driving it
Old Sep 30, 2011 | 09:45 PM
Anyone else have anythinf on my problem??????why would the ses light stay on then turn off causin the car to drop RPMS...
Old Dec 5, 2011 | 03:24 PM
Fixed the prob...MAF WENT BAD
Old Dec 5, 2011 | 05:02 PM
fivestar's Avatar
Engine: IROC V-8
Yup same thing happened for me. Changed out my MAF sensor and it runs great now and gets just a bit more gas mileage. I am down in Phoenix on a month long trip and enjoying the convertible IROC with Nov/Dec weather.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
