350 TPI problem
Old Dec 27, 2011 | 01:19 PM
  #51
Pajjen's Avatar
Car: Pontiac Trans Am GTA -87
Engine: 5.7 TPI
Re: 350 TPI problem
No i didnt, but i spoke to a guy about the ECM today. He lives near me so that may help me out a bit. He said that the ECM should be exactly the same as mine, but the prom is meant for bigger injectors.
Old Dec 27, 2011 | 01:43 PM
  #52
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: 350 TPI problem
Excellent, you will be able to determine if the prom or ecm is causing code 41.
According to WinALDL; when the car is running does the O2 function properly (its values should vary between 0.1V and 1.0V)? What do the BLM's do? What do the INT's do?
What is the fuel pressure? I am concerned your injectors are leaking.
Hope this helps...
Old Dec 27, 2011 | 01:47 PM
  #53
Pajjen's Avatar
Engine: 5.7 TPI
Re: 350 TPI problem
I have to check tomorrow, i havent tested the fuelpressure. maybe it would be good to know. i think my friend have a fuelpressure gauge that fits directly to the fuelrail, have to ask him
Old Dec 27, 2011 | 01:52 PM
  #54
skibum2100's Avatar
Car: 1988 GTA
Re: 350 TPI problem
Excellent, the pressure should be ~42-47 psi with FPR vacuum line removed/plugged.
Good luck...
Old Dec 28, 2011 | 05:07 PM
  #55
Pajjen's Avatar
Engine: 5.7 TPI
Re: 350 TPI problem
my friends gauge does not fit to the fuelrail but im going to ask another guy.
i was also reading data, i took some screenshots on the rawdata and dash.
in raw data the blm was 128 on 800 rpm and int was the same.
in the screenshots i got another value on the blm when i gave it throttle.
Old Dec 28, 2011 | 09:09 PM
  #56
skibum2100's Avatar
Car: 1988 GTA
Re: 350 TPI problem
Did you give the car enough time to reach operating temperature?
Old Dec 29, 2011 | 01:24 PM
  #57
Pajjen's Avatar
Engine: 5.7 TPI
Re: 350 TPI problem
Maybe not full operating temp. but i had it running pretty long time.
I also spoke to the guy with the ECM, it was sold many years ago
He thought he had it, but then he remembered that he sold it.
So.. did someone of you have an ECM for sale?
Havent tested fuelpressure yet...
Do i have a EGR temp switch on my car?
Can EGR switch and knock sensor have something to do with my problem?
they havent been changed.
Old Jan 19, 2012 | 02:55 PM
  #58
skibum2100's Avatar
Car: 1988 GTA
Re: 350 TPI problem
Hi Pajen,
Any updates?
I do have a computer I would be willing to sell.
Cheers,
Vince
Old Jan 20, 2012 | 04:40 PM
  #59
Pajjen's Avatar
Engine: 5.7 TPI
Re: 350 TPI problem
Yes!
Now its running, i bought a ECM and Prom from tunedperformanc
The car runs fine now, but its so much snow here so i cant testdrive it.
Now i have a lot of other stuff that has to be done to the car before the summer.
Thank you all that helped me out on this!
Cant wait to
Old Jan 20, 2012 | 05:08 PM
  #60
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Re: 350 TPI problem
Pajjen,
What prom did you use?
Old Jan 20, 2012 | 05:10 PM
  #61
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 350 TPI problem
Once you have a chance to drive it. I might be able to salvage your hypertech with a new moated.net d2 and a new reprogramed eprom.
Old Jan 21, 2012 | 01:31 AM
  #62
Pajjen's Avatar
Engine: 5.7 TPI
Re: 350 TPI problem
Hmm.. i dont really know, its something tunedperformanc sold to me. and i trust him.. so.. im a bit about the proms
Originally Posted by IROCU2
Pajjen,
Old Jan 21, 2012 | 02:07 AM
  #63
Engine: Lb9
Transmission: M20
Re: 350 TPI problem
The mescal was a older $32b that I uv erased and reprogramed to a $6e L98 automatic with a little better timing.
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
