85 TPI stalls when slowing down or stopped?!?
Old Jan 7, 2012 | 05:40 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
Sometimes my 85 305 TPI will stall when i am slowing down to stop or when i am stopped.
Ive recently replaced my spark plugs, plug wires, distributer cap, and starter and the fuel pump is only 1.5 years old.
What could possibly be causing this?
-Thanks
Old Jan 9, 2012 | 06:27 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: 85 TPI stalls when slowing down or stopped?!?
Could you have a lean idle condition caused by unmetered air(vacuum leak)? Does the engine idle rough also? Could the EGR valve be stuck open?
Old Jan 9, 2012 | 08:02 PM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
Check your TPS and Idle valve
Old Jan 9, 2012 | 08:10 PM
camarorookie's Avatar
Go through the set minimum idle procedure, and if this doesn't fix it, verify that your ICV is extending and retracting. If the idle was off you will have to re-adjust your TPS.
I just recently help track an idle problem on an 86 where the ICV wasn't working properly so the owner adjusted the idle screw to keep it idling. Part of the whole mess was that he had a tear in his intake boot, after the MAF, that was letting unmetered air in the system also. After replacing the ICV and boot we had to go back and set minimum idle and adjust the TPS. Runs like new now.
Old Jan 9, 2012 | 09:53 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
The engine does idle rough and does not keep a constant rpm when idling. Could this be because of a vacuume leak?
Also, how would i go about checking if the egr were stuck open?
Old Jan 9, 2012 | 09:54 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
The TPS has been replaced, but im pretty sure the idle valve is original..would it be better to just replace it with a new one?
Old Jan 9, 2012 | 09:56 PM
m16a2r's Avatar
Transmission: 700r?
my car was dying on me when slowing down or making turns, almost got in wreck couple of times, replaced idle control valve, fixed the problem but still had jumpy idle, replaced tps sensor, now it runs great
Old Jan 9, 2012 | 11:18 PM
nickfrmtx89's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
my 92 camaro rs sometimes does the exact same thing. i had my head gaskets replaced along with alot of cooling parts about 7 months back, when i got the car back it has not overheated once but a new problem occured. it idles weird and acts up after i take it on long trips. RPM's jump up-down,stalls, sometimes it runs perfect and sometimes i can hardly get it home. i'v put a new MAP sensor, TPS, replaced plug for IAC(broken) and replaced 1 injector(broken), replaced the IAC and fuel filter. i suppose i'v replaced everything to do with fuel delivery except the EGR valve and fuel pump.
Old Jan 10, 2012 | 12:50 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Turned out my erratic idle was caused by bad injectors (after replacing nearly everything else). It got so bad before I replaced them that my car would barely run.
Old Jan 10, 2012 | 05:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Does speedo work correctly when this happens?
Old Jan 11, 2012 | 11:24 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
On TPI cars you cant access the valve to test it with your fingers. You can however use a vacuum pump to open the valve. With the engine at idle, opening the EGR valve should have a huge impact on idle quality if not stall the engine. If you don't get a big reponse to opening the valve, it probably means the valve is stuck open. It's best to use a smoke machine to check for air leaks in the intake, but carb cleaner or even brake cleaner also works. Carb cleaner will cause the idle to rise and smooth out whem it hits a leak. Brake cleaner will cause the engine to stumble. Brake cleaner is easier on paint and plastics than carb cleaner.
Old Jan 14, 2012 | 08:20 PM
darrlee's Avatar
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
I would check the injectors as well. That it is what I finally tracked my problem to be. There are several threads on how to check them for leaks.
Old Feb 26, 2012 | 01:04 AM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Sorry for the extremely late reply, havnt been on in a while.
Sometimes as slower speed, the speedo does seem to jump around slightly
jklein337
Sep 19, 2018 06:23 PM
pfsteichen
Feb 9, 2016 06:59 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Sanjay
Aug 12, 2015 03:41 PM
