Vortec TPI
Car: 1989 Iroc Z L98
Vortec TPI
I have a set of like new Vortec heads in my garage that I purchased on Craigslist. I have done a few searches on here, in particular I found this article:
http://www.camaroperformers.com/cama...l/viewall.html
Where a mostly stock TPI, SDPC vortec base 350 makes 305 horsepower by swapping to Vortec heads with the stock cam.
I have a 1989 Iroc Z with L98 and 90k miles on it. I was considering purchasing the Edelbrock Vortec base and putting the heads on my stock shortblock.
Any advise on this? I didn't find a whole lot of threads with results in them on this. I know that the Vortec heads flow about 40 cfm better than a stock L98 head, and the low lift #'s are great as well. If I did this, I would probably even leave the stock camshaft in since the shortblock has 90k miles on it and I wouldn't want to mess with piston to valve clearance.
Thanks in advance!
Thanks in advance!
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Vortec TPI
The mileage of your motor has nothing to do with piston to valve clearance. You'll never have PTV issues with a cam that's mild enough to work with TPI.
There aren't a lot of guys with a lot of good things to say about the Vortec TPI setup, but I think that for a street car, it'll make a good combination. I hope I'm right, because I'm doing one right now myself. The big bottleneck with a setup like this is the lousy flowing SDPC/Edelbrock intake base, and there's not really much that can be done about it, but as long as you build the rest of the combination to optimize performance at lower RPM, I think this can still be a good combo. While you have the motor apart, I'd definitely think about adding a cam. The stock cam sucks, and a nice mild cam can only help with new heads.
Re: Vortec TPI
Thanks for the reply, definitely let me know how it turns out. Where did you find your manifold, I can't find one for much less than $480...
Re: Vortec TPI
Would I make more power with the stock TPI and a different set of heads that flow similar to Vortec heads?
I suppose if I have to invest nearly $500 into a manifold, I could sell my Vortec heads and put that money towards a new set of heads that would fit the stock TPI setup.
Car: Faster
Engine: Than
Transmission: You!
Re: Vortec TPI
If you are going the vortec route, with a good set of runners and port your plenum, you can make enough power to have some fun...
I use the cc503 cam in my motor
Re: Vortec TPI
I bought the SDPC (Skoggin Dickey) manifold used. SDPC sells it new for $400. It's identical to the more expensive Edelbrock manifold.
To answer your question about power with other sets of heads, generally, yes, with any set of good flowing aftermarket heads and an aftermarket base & runners, you'll probably make more power than with the Vortec setup. I went with the Vortecs because I already had the heads. If I didn't already have them, I never would have gone this route. By the time you get vortec heads that can handle any kind of cam, and buy the SDPC base, you're really not saving much money compared to a set of Trick Flow 180s and an accel/TPiS base, which will yield better results.
Re: Vortec TPI
Re: Vortec TPI
I've done so much reading on this subject it'll make your head spin. I really wanted to see what could be done with such an efficient vortec head, especially on a TPI. Most of what I read really shows people mismatching intakes, exhaust, cams, etc. etc. I was hoping to build a much milder vortec motor (than most) but had hoped it would perform up there with the "bigger" mismatched combos that I see so much of. .....however....at the end of the day, the Vortec manifold just turned me off to it. I didn't want to match the whole engine around a the most expensive part, which has NO moving parts, yet was the bottleneck of the whole operation. That manifold just really turned me off.
That being said, I'm also a fan of the idea of putting down the mouse, turning off the computer and just enjoying what you have. That being the case, I think a vortec head TPI, even with that manifold would really be enjoyable on the street.
Re: Vortec TPI
Re: Vortec TPI
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Vortec TPI
I just finished a vortec TPI build in my 85. I went with an LT1 cam and SLP runners. I did get the block for free but it needed a new crank and bearings all around as well as rings. Including the intake I spent around $1000 on the motor. I am very happy with the end result as it has way more power than the 305 that was in there and I haven't even finished tuning it. I also swapped in a T56 which was also around $1000 so for about $2000 I got a fresh motor and trans.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Vortec TPI
Re: Vortec TPI
I'm not sure I'm familiar with the back-story of the TPI bases. Since I bought my accel back in the early 2000s, I mostly stopped paying attention. I do know that those old accel bases seem to be in mighty high demand now though, but I decided that I'm holding on to mine. I can't imagine that I won't wind up with another TPI small block down the road.
Engine: 4++,350 & 305 CIs
Re: Vortec TPI
Does anyone know the flow numbers on the different bases?
SDPC
Accel
Edelbrock
stock.
maybe we should have a flowbench party with them..
SDPC
Accel
Edelbrock
stock.
Re: Vortec TPI
I think one of the guys socal guys did flowbench them fairly recently. ...I've seen the thread, but I'm not sure exactly which one it is.
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
