What IAC to use????
Old May 1, 2012 | 11:27 AM
DBRjeep350TPI's Avatar
What IAC to use????
I have one for you guys… I have a TPI unit from an 87 Camaro 350. I did plug off the 9th injector and all to convert the unit to run with a 90-92 1227730 ECM. Well my question is on the IAC unit. I left the 87 IAC unit in and believe I replaced it with a new 87 IAC unit. I went out the other day and the engine was running a little odd, I did not hear the IAC like normal. I pulled the unit out and found the cone on the end unscrewed inside the throttle body. I threaded it back on and now seems to start and run okay, but intermittently the idle will jump from 900 to 1800-2000 RPM and smells like it is running rich and burning fuel more than usual.
I am curious if the IAC I am using is the correct one for my application?
Dose the IAC fit the throttle body per application (87 or 90-92) or should I match the IAC to the ECM/ECU being used (an 87 IAC to an 87 ECM/ECU or a 90-92 IAC to a 90-92 ECM/ECU)?
Old May 1, 2012 | 11:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What IAC to use????
85-92 tpi iac's are the same. I like to use the lower iac plate from a Lt1 just change the harness end or build a pigtail.
Old May 1, 2012 | 12:09 PM
So if they are the same... why are they two diffrent part numbers AC16 (90-92) and AC1 (89-older) and also the cost for the AC16 is three times as much?
You say you like to use the "lower IAC plate from an LT1" not sure what you mean? I understand to rebuild the harness.
Old May 1, 2012 | 02:04 PM
Engine: Lb9
Transmission: M20
you could use a acdelco pt757 or accel 77651 and get the lower iac plate with iac usually on a used throttlebody on ebay for a lti. The lt1 lower coolant /iac housing bolts to a tpi throttle body. huh, looks like there is a difference the 89-92 use a iac coolant housing 17112127 the 85-88 must be different you can see the year date on yours and order the correct iac aswell.
Old May 1, 2012 | 02:12 PM
My housing/throttle body is from an 86-87... I was curious if I do use a IAC for that housing or should I use the IAC for a 90-92? I am curious is the ECM/ECU is adjusting the IAC differently?
The two IAC from 85-88 and 89-90 look identical physically, but is there some internals of the IAC that are different that the ECM/ECU might be controlling?
Old May 2, 2012 | 06:22 PM
Engine: Lb9
Transmission: M20
might be pintle length or tip shape no sure.
Old May 2, 2012 | 06:28 PM
Engine: Lb9
Transmission: M20
for example check the link for the throttle body, use the lower plate and iac, if you need a new iac there cheap, gasket set go to autozone and get gp sorenson 96-3008
http://www.ebay.com/itm/96-Caprice-9...#ht_500wt_1075
http://www.ebay.com/itm/ACDelco-217-...#ht_500wt_1075
Old May 3, 2012 | 09:01 AM
your awsome man!!!!
and that throttle body will bolt on directly to a 87 TPI system from a IROC?
Old May 3, 2012 | 09:30 AM
Engine: Lb9
Transmission: M20
the throttle will bolt on but there is no provision for the 700r4 tv cable, just swap over the lower plate that the iac it attached to. I usually pull out the coolant pipes to clean up the look.
Old May 3, 2012 | 09:34 AM
I see...
One other thought. When you switch over that lower body and use the newer style IAC. Is the operating range/temp the same? I dont want to start throwing codes cause of the new sensor.
Old May 3, 2012 | 02:39 PM
Engine: Lb9
Transmission: M20
Originally Posted by DBRjeep350TPI
I see...
The iac controls a vacuum leak and just moves in and out. Temperature range not sure what you mean ?
Old May 3, 2012 | 02:49 PM
Not Temp range... sorry I ment that my 1227730 ECM/ECU will read the correct signal from the new IAC valve. So it wont throw a code
Old May 3, 2012 | 03:47 PM
Engine: Lb9
Transmission: M20
I have used it on a couple 730 with no issues. If you like a second opinion maybe ask rbob
Old May 3, 2012 | 03:48 PM
as long as you have done it and no troubles on a 7730... I believe you. just want to make sure.
thanks
Old May 3, 2012 | 04:06 PM
Engine: Lb9
Transmission: M20
you can easily make a adapter like this !
I used a delphi 12162188 and 12015024
http://www.mouser.com/ProductDetail/...Ioj78ZJeGKE%3d
http://www.mouser.com/Search/Product...4PGCdjsA%3D%3D
Old May 3, 2012 | 04:28 PM
Engine: Lb9
Transmission: M20
A=IAC "B" low Lt. Grn/Blk
B=IAC "B" high Lt. Grn/Wht
C=IAC "A" low Lt. Blu/Blk
D=IAC "A" high Lt. Blu/Wht
Old May 3, 2012 | 04:32 PM
Awsome... Thanks
Old May 3, 2012 | 04:34 PM
Engine: Lb9
Transmission: M20
you owe me a cold beer. lol
Old May 3, 2012 | 10:23 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
When I go to CO (hopefully in 2013), I'll stop by with a nice little 6 pack to catch a tiny buzz. Lol
Old May 3, 2012 | 11:07 PM
Engine: Lb9
Transmission: M20
Come on out man .
Old May 3, 2012 | 11:19 PM
Come on out man .
If it wasnt for the 1200 mile drive, I'd be right there in two shakes of a lambs tail. LOL
Old Nov 1, 2012 | 08:06 PM
Engine: Lb9
Transmission: M20
the letters "A" and "B" are just referring too the coil a and coil b sorry for the confusion
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
