stripped out a torx bolt...HELP!!!
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
any recommendations on how to remove a stripped torx bolt to the plenum?
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: stripped out a torx bolt...HELP!!!
If you grab some heavy duty wire snippers, you can get a good grip on the bolt head and slowly turn it. Use this style; http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if the above doesn't work,could use a dremel to make
a screwdriver slot in the head of the stripped torx bolt
Thanks for the tips guys. I ll give em a go tomorow.thanks again
Engine: 4++,350 & 305 CIs
Make sure you have the correct sized tool and its not rounded off.
I can sometimes get the bolt out with some valve grinding compound, put it on the tip for more grip.
Car: 89 Irocz
Axle/Gears: 342
http://www.autozone.com/autozone/acc...er=532381_0_0_
btw best thing to do to make sure you got the right size take one of your other bolts with you to make sure it will fit. but this will do it, trust me I've been fighting with these torque bolts for years lol.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i used an adjustable pipe wrench i had in my garage... should work also...
weld a nut to the head, lay nut on there and fill in the center with a weld puddle.
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
What I found to be the easiest way was to just drill out the head of the bolt. If you drill out the center of the bolt the head of the torx bolt will fall off allowing you to remove the plenum and the runner flanges are so thick the there will still be enough of the bolt sticking out of the plenum to grab it with a pair of vice grips or weld a nut on.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
yeah try that first, if they doesn't work got to autozone and get this
James Sutton
Sep 23, 2015 01:56 PM
