Good ALDL cable on ebay ?
Old Jul 21, 2012 | 09:38 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hey guys,
Im just wondering if anyone has bought one of these cables before, seems like a good price if it just plugs into the laptop.
http://www.ebay.com/itm/GM-OBD1-Scan...53c3e1&vxp=mtr
im thinking of buying one and downloading tunerpro to see whats really going on inside my TPI system after discovering lots of shoddy wiring, the car not running right etc etc
Ive never tried anything like this before so im hoping its fairly straight forward to look at
Scott
Old Jul 28, 2012 | 06:27 PM
phonedawgz's Avatar
Re: Good ALDL cable on ebay ?
Hi
I am the supplier of the ebay cable. If you have any questions on how it works feel free to ask me.
Also you can save by skipping ebay and going to my website directly. http://reddevilriver.com
phonedawgz
Old Jul 28, 2012 | 06:30 PM
91zl98's Avatar
Car: iroc z
Engine: 383 in the works
Axle/Gears: 3:73
can't you just use one of these ?
https://www.thirdgen.org/forums/diy-...converter.html
Old Jul 28, 2012 | 06:31 PM
91zl98's Avatar
Car: iroc z
Axle/Gears: 3:73
http://www.ebay.com/itm/Arduino-FT23...item3cbfdfc861
Old Jul 28, 2012 | 06:37 PM
phonedawgz's Avatar
Yes you can build your own cable with a FT232-RL USB to TTL board. Note - most/all other USB to TTL cables don't seem to work.
Old Jul 28, 2012 | 06:43 PM
91zl98's Avatar
Car: iroc z
Axle/Gears: 3:73
Seems like a cheap option.
Old Jul 28, 2012 | 06:48 PM
phonedawgz's Avatar
Yes it is a cheaper option for those who are comfortable with making their own interface cables. Don't forget you also need the additional electronics/hardware per your linked thread. I use a slightly different schemetic than shown in the thread, however I don't know if there is any functional difference between what the thread has and mine. I just know what I make works well.
You will also want to make sure you use the correct ALDL connector, either the 12 pin ALDL plug for the 85-about 93ish or 16 pin OBD2 TYPE connectors. Note also - Most 94 and 95 16 pin OBD2 connector cars are connected to OBD1 electronics ECMs.
Old Jul 28, 2012 | 06:51 PM
91zl98's Avatar
Car: iroc z
Axle/Gears: 3:73
Why does yours have all the tape over the wires?
Old Jul 28, 2012 | 07:04 PM
phonedawgz's Avatar
It actually doesn't. That was an early version. The 12 pin ALDL cable I used for the mock up didn't support all the pins needed (A,B,E, and M). I really need to take a new picture. The Ebay picture shows the cable without the tape.
Old Jul 28, 2012 | 07:10 PM
phonedawgz's Avatar
Does this look better - I updated the picture.
Old Jul 29, 2012 | 03:15 AM
gta_knight's Avatar
Car: 1987 GTA
well i wouldnt waste my time trying make a cable so that option would be best for me ive downloaded tuner pro to have a look but im not sure how it works, i think i need to download a bin file or something to get all the info for my car
Old Jul 29, 2012 | 07:27 AM
phonedawgz's Avatar
Here are some videos I made to help with set up and operation.
http://www.youtube.com/playlist?list...ature=view_all
Old Jul 30, 2012 | 06:24 PM
88I-ROC's Avatar
Car: 1988 Camaro Iroc-Z
Axle/Gears: 3.08
I was wondering, I looked at the website and seems you have another type of cable which is the same but offered cheaper than the one mentioned above. Whats the difference?
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
the_nikfive
Aug 11, 2015 02:46 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
