injector or valve guides or?
1990 firebird formula 350 tpi.
its a 85,000 mile car. runs real smooth. drives whit no problems.
on cold start ups, it shoots a puff of smoke. only on cold start ups. i assumed maybe some injector was leaking, but i feel no stumbling problems at all. The car runs as you would expect a 80k mile car to run. How can i find out what the problem is? any ideas or inputs would be appriciated. thx
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: injector or valve guides or?
Probably seals are old and letting some oil through.
Bet the guides are fine
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
yeah my car is original 93k mile car and the seals let some oil through. it's kinda normal with the SBC engine
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Your car is still 22yrs old. your valve seals are 22 yrs old, they get brittle and leak a little. How can you check them? Take the valve covers off and replace them.
Car: 91 Trans Am
Engine: 355 TPI
yeah the only way to check them is to pull the valve covers and look at them. They can be changed but it can be fairly complicated if you don't know what your doing. you can really screw it up and then valve seals are the least of your worries
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
If you need help isolating one from the other, I can explain some basic tests.
Pick up a pair of hose clamp pliers too. You'll need them if you decide to do any testing. Your car should have the rubber fuel lines at the end of the fuel rail.
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
Like most have stated..valve stem seals. If it were leaky injectors, the hot starts would be affected too.
ambainb
Apr 25, 2016 09:21 PM
