Emptying gas tank
Old Dec 9, 2012 | 06:59 PM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
Emptying gas tank
I have a 90 5.7 TPI and want to empty the tank because it has sat for too many years.
I have tried to siphon but can't get the hose to the gas.
I know about the fuel lines by the steering shaft.Which one comes out of the tank?
How do I keep the fuel pump running to empty the tank?
I also have the 'air Bag" light on and would like to trouble shoot whats wrong with it.
Old Dec 9, 2012 | 07:37 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Emptying gas tank
There are 2 lines up by the engine, the slightly larger one is the supply. Jump the orange and grey wires on the fuel pump relay and the fuel will pump out of that line.
Old Dec 10, 2012 | 04:36 AM
BigBlock73's Avatar
Engine: 5.7
Were is the relay located?
Thanks for the info
Old Dec 10, 2012 | 04:42 AM
Twin_Turbo's Avatar
The pump will ever totally empty the tak. The only way is to either punch a hole in the bottom (bad idea if you are not welding a sump over it) or removing the tank. Then remove the whole pickup/sender unit and us a siphon pump to remove the fuel
Old Dec 10, 2012 | 06:23 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
To get pump continious running,supply +12v to aldl connector G(listen pump sound,dont let it run dry)
Old Dec 10, 2012 | 06:00 PM
BigBlock73's Avatar
Engine: 5.7
Twin_Turbo
I'm not looking to get every last drop out.It has at least 1/2 a tank of old gas and I don't want to take a chance.It has 26K miles and most of those miles were in the first 4 years.It was last inspected in 2006.
z 28 jari
I see you have a 85,I store my car 2 hours from where I spend the week and only see it on the weekends.
Is the 1990 ALDL the same as a 1985.
Were is the fuel pump relay located on a 90
Old Dec 13, 2012 | 01:50 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
relay should be on driver side firewall next to brake m/c. make sure you jump the right one cuz there should be one (or two) more for the cooling fan(s). you can tell by the wire colors, tho...
Old Dec 16, 2012 | 08:33 AM
BigBlock73's Avatar
Engine: 5.7
Pulled the connector into the relay and jumped the Orange and Grey wires.The pump ran and I emptied 5 gallons of old gas out.
Thanks for the help
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
