tpi350 or tpi305
Old Dec 15, 2012 | 12:29 PM
Randell Howell's Avatar
tpi350 or tpi305
Hello, I need to know what engine has been put in my car. It's supposed to be a 89 iroc 350 tpi. How can I tell without tearing it apart ? Are there numbers anywhere ? Thanks
Old Dec 15, 2012 | 12:46 PM
Guest
Guest
Posts: n/a
Re: tpi350 or tpi305
Yea, on the back of it...most likely the passenger side. it will say 5.0 or 5.7
Old Dec 15, 2012 | 12:50 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
the suffix is on the passenger side front of the block under the cylinder head. The block casting number is on the drivers side rear of the block under the cylinder head and can be viewed from the top side of the engine.
Old Dec 15, 2012 | 02:56 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Behind driver's side head on the top of the block right before transmission. you will need a flashlight to see. It should either say 5.0L or 5.7L
Old Dec 15, 2012 | 10:04 PM
Guest
Guest
Posts: n/a
..............I just said that...............
Old Dec 15, 2012 | 10:44 PM
ninetyone's Avatar
Axle/Gears: 3:42
No, you said passenger's side head.
Old Dec 16, 2012 | 12:35 AM
Tilly's Avatar
Car: 85 yellow z28
Engine: 305(lb9), tpi
the 8th digit of your vin#
if it`s an f it is 305tpi
if it`s an 8 it is 350tpi
Old Dec 16, 2012 | 09:14 AM
Guest
Guest
Posts: n/a
....its in the same vicinity....
86 toy
Apr 2, 2011 10:26 AM
lameusername
Jan 21, 2011 12:28 AM
77tpi nova
Nov 22, 2008 11:11 PM
rtfrew
16
Jul 23, 2008 03:46 PM
firebird13
Feb 14, 2003 02:47 PM
