Cam quest.....
Old Feb 25, 2013 | 06:16 PM
UBHSTRY's Avatar
Cam quest.....
Hoping for a little help on cam selection. I did some searching, but really couldnt locate anything too specific.
Here is my set up, and I need to get a cam for it.
NON-Roller cam.
383
edelbrock 60909 performer heads
Stealth ram intake
24lb injectors
And I need a good NON roller cam. I was hoping to hear some suggestion from everyone here. Nothing so big it requires a 3500 stall...LOL
Old Feb 25, 2013 | 07:28 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Cam quest.....
comp 12-249-4, 12-388-4, 12-364-4.
Old Feb 25, 2013 | 09:04 PM
UBHSTRY's Avatar
Re: Cam quest.....
I notice on all three of them they are suggesting you use 1.6 rockers. I have a nice set of 1.5 roller rockers, and I dont think that will be an problem, do you?
Old Feb 25, 2013 | 09:06 PM
Re: Cam quest.....
If you plan to use 1.5 rockers I'd get the bigger cam. What type of rockers do you have?
Old Feb 25, 2013 | 09:17 PM
UBHSTRY's Avatar
Re: Cam quest.....
I dont know the brand...here is a pic....I hope.
I was planning on getting the bigger of the 3.
12-364-4
Old Feb 25, 2013 | 09:28 PM
Re: Cam quest.....
Look like crane energizer rockers. I use those also.
Old Feb 26, 2013 | 06:51 PM
UBHSTRY's Avatar
Re: Cam quest.....
Lift: .477"/.472" With 1.6 Rockers
I was thinking, I believe my set up could go with more lift.......what do you think skirkland? Ah, I hate picking a cam....... Maybe I should just order that one.
Lift: .477"/.472" With 1.6 Rockers I will NOT be using the 1.6 rockers though.
Duration: 252°/266°
Lobe Separation Angle: 113°
RPM Range: 1300-5300
My roller rockers are Summit brand FYI. I found some of the paper work from when I first built the engine for the boat.
By the way, who would I need to email about using my original SN from 1997? Or from 1999, when I think the board was redone.
Old Feb 26, 2013 | 07:10 PM
Re: Cam quest.....
Is the engine going in a boat? What type of fuel injection are you using? I don't understand the last sentence of your last post.
Old Feb 26, 2013 | 07:16 PM
UBHSTRY's Avatar
Re: Cam quest.....
I originally built it for a boat. But after 70mph, it was too scary for the guy. (It was just a fishing boat). So, I am using it in my IROC now. Screen Name......I was wondering who runs the place now, so I could maybe get my first screen name up and running again.
I am using the Holley Stealth Ram.
Old Feb 26, 2013 | 07:19 PM
Re: Cam quest.....
Contact JT. What is controlling your fuel injection?
Old Feb 26, 2013 | 07:20 PM
UBHSTRY's Avatar
Re: Cam quest.....
Plan on using the stock ecm. But, I also have a megasquirt that can be used. Prefer to just use the stock ecm for now, I plan on transitioning to the megasquirt when i can plumb the turbo in. But, thats another project, and will be hunting a different cam down at that time, and probally go roller with it at that time.
Old Feb 26, 2013 | 07:23 PM
Re: Cam quest.....
What version of megasquirt?
Old Feb 26, 2013 | 07:25 PM
UBHSTRY's Avatar
Re: Cam quest.....
v2....it was running my turbo lexus sc300.
Old Feb 27, 2013 | 09:25 AM
UBHSTRY's Avatar
Re: Cam quest.....
Wow, I stand corrected. The megasquirt is a V1 I am getting old.............
Old Feb 27, 2013 | 11:10 AM
Re: Cam quest.....
Is it the green board?
Old Feb 27, 2013 | 12:06 PM
UBHSTRY's Avatar
Re: Cam quest.....
Yes it is.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
