Car just shut off?
Car: 89 Iroc
Transmission: 700R
Car just shut off?
I was driving kids to school and I came to a stop to make a left turn as I completed a full stop boom the car just shut off I didn't get worried because i put it in park and it turned right on but it's not giving me any codes what can I do to figure this out? And it turned off while I was holding the brake.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Car just shut off?
A intermitant problem like this can be hard to pinpoint. It maybe the icm, or fuel related. Its allways a god idea to keep a spare icm in the car anyways.
Engine: Lb9
Transmission: M20
icm= Ignition control module, if the egr was being held open your idle would have been rough.
Car: 1990 Trans Am
Axle/Gears: Stock
On the 3.1 V6s the combination of steering, braking and slowing down sometimes caused the engines to stall. In some cases the pressure switch on the power steering boxes needed to be changed, in others the PROM was still learning new values for its tables after having the battery disconnected (which will not be the case on your engine).
Just one possible cause.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Car: 89 Iroc
Transmission: 700R
My injectors are good not even a year old and I forgot to mention that when I brake the engine hesitates like if I revved it
Linson
Aug 21, 2015 02:12 PM
db057
Aug 11, 2015 10:11 PM
