New Member: Ideas on build
Old Mar 13, 2013 | 02:58 PM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Hi my name is Sam.
I just registered to this forum today.
Yesterday I bought a 1986 305 Iroc for $1000
It does not have a transmission as of now.
The stock 305 is already pulled and has a blown head gasket.
I'm going to rebuild the whole engine (new cam, heads, etc) and i think i should keep the tpi system over carbarated, but im not sure.
I will be converting it to a 350.
The interior is all there and very nice.
Also i want to convert it to manual since it needs a transmission.
Any suggestion before i start this build?
Attached Thumbnails New Member: Ideas on build-601204_10151478046948996_720886389_n.jpg   New Member: Ideas on build-photo-16-.jpg
Old Mar 13, 2013 | 03:08 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: New Member: Ideas on build
Originally Posted by TBRays98
Hi my name is Sam.
Read the thousands of threads here. There are many ways to go, most have gone them before.
When decided what to build, you first need to decide what do you want to do with the car, and second what is your budget.
TPI is great, but it has limits. There is a ton of info on the auto to manual swap as well.
Welcome!
Old Mar 13, 2013 | 03:18 PM
TBRays98's Avatar
Car: 1989 Formula
Thanks i appreciate the information. I just want a somewhat fuel efficient daily driver with medium sized *****. My budget on the engine build and tranny install is about 3k and i can do all the work myself. Plus i work at Advanced Auto Parts so i get a nice discount.
Old Mar 13, 2013 | 03:22 PM
Car: 1971 Camaro
Engine: 427
Rebuild the tpi ad a small cam, headers, and the usual other bolt ons and you'll be happy.
Old Mar 13, 2013 | 03:24 PM
TBRays98's Avatar
Car: 1989 Formula
what type of cam does a 1986 use? flat? or roller?
Old Mar 13, 2013 | 03:29 PM
Car: 1971 Camaro
Engine: 427
Flat tappet.
Old Mar 13, 2013 | 03:44 PM
busterbrown's Avatar
Car: 1992 formula firebird
Engine: 355 TPI
Transmission: currently a T-5, eventually a T-56
Axle/Gears: 3:42
keep in mind when you do rebuild the engine you will need to have the chip recalibrated, or you coud just buy a new aftermarket one.
Old Mar 13, 2013 | 03:49 PM
TBRays98's Avatar
Car: 1989 Formula
Yea i would have brian from tpi chips make me one. Quick question though (i am looking through the forum) even with new heads on my 305 block i can still only use a flat cam?
I want this engine near 300hp so i was originally thinking i could do that with vortec heads a bigger cam and then exhaust and bolt ons. Am i wrong? Just really confused on the limitations of a 1986 305 block
Old Mar 13, 2013 | 03:52 PM
Engine: 355 TPI
Axle/Gears: 3:42
if you go with vortec heads you will need to buy an aftermarket base for your tpi. flat tappet cam isn't your only option, you could install a roller cam with retro fit lifters if your block doesn't have the bolt holes for the factory lifter retainer. it will be more costly to your budget though
Old Mar 13, 2013 | 03:55 PM
TBRays98's Avatar
Car: 1989 Formula
ok thanks, i have a lot of rearch to do...
Old Mar 13, 2013 | 03:57 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
do a 5.3 you will be happier in the long run more power and better driveability shop smart and you can do it on the cheap
Old Mar 13, 2013 | 03:58 PM
lunati397's Avatar
lol we will bring them all over to the dark side
Old Mar 13, 2013 | 05:10 PM
Car: 1971 Camaro
Engine: 427
There goes that budget!
Old Mar 13, 2013 | 09:48 PM
TBRays98's Avatar
Car: 1989 Formula
are all 1986 blocks flat tappet? and is the 305 tpi even worth having? I havent grabbed the engine yet but is it worth it? Can i make a 300hp motor with that engine? Need to know quick bc im suppose to grab the engine this week.
Should i just take its intake and grab a 350 block that can take a roller cam. Need help....
Old Mar 14, 2013 | 05:39 AM
Engine: 355 TPI
Axle/Gears: 3:42
300hp out of a 305 isn't out of the question, however it would be far easier and less costly to get 300+ hp out of a 350,
Old Mar 14, 2013 | 07:49 AM
Car: 1971 Camaro
Engine: 427
If you don't have the engine already, get a one piece rear main seal 350. You'll be starting off ahead of the game, bigger engine, set up for roller cam, etc...
Old Mar 14, 2013 | 08:43 AM
lunati397's Avatar
5.3 can be gotten for 500 to 600
edelbrock intake with ingition controller is 640
swap mounts are 75
fuel pump and regulator 100
carb 250
accy brackets 500 (dirty dingo)
cam springs and pushrods 650
Headers if you want them but you can get away with stock manifolds to start
Sell the fuel injected intake wireing and ecu If you got it and you can make back another 3 to 400
Thats your bare bones cheapest LS swap you can do and make close to 400 hp Crank
I didnt include trans becuase that would be the same with either or but with the LS you will need the 70 dollar adapters for the TQ and flexplate
Old Mar 14, 2013 | 08:58 AM
Car: 1971 Camaro
Engine: 427
$3000 invested, and you still have a used engine of questionable history and condition.
I am not against Ls swaps, but I don't think they are the best choice for a limited budget.
Old Mar 16, 2013 | 10:43 PM
TBRays98's Avatar
Car: 1989 Formula
i dont want to carb it and of course if i see a cheap enough ls1 ill grab it
Thanks johnny ill look for a one piece rear main seal
toones
Jan 6, 2016 06:00 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
perZ
Aug 15, 2015 01:17 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
