Oil Temp sender location
Old Apr 7, 2013 | 12:24 PM
Msaby's Avatar
I have a 91 chevy 305 TPI, I would like to install a VDo oil temp gauge. I am unsure as to where to install the OIL temp sensor for an accurate reading or which OIL temp sensor I need to purchase. Any advise would be greatly appreciated.
Mike
Old Apr 7, 2013 | 02:09 PM
TFS355S10's Avatar
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
Re: Oil Temp sender location
An oil temp sender needs to be in the oil pan.
Old Apr 7, 2013 | 05:10 PM
Msaby's Avatar
Can I replace the oil drain plug with the sensor? If i can install the sensor in place of the drain plug, any idea the thread size of the oil pan.
Mike
Old Apr 7, 2013 | 08:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The factory oil temp sender on Vettes is fitted in the oil gallery port above the oil filter so it shows the true temp of the oil in the engine
Old Apr 8, 2013 | 01:44 AM
TFS355S10's Avatar
I didn't know vettes had an oil temp gauge, but then I haven't been around 'em much either.... LOL
Not saying it isn't a temp sending unit, but that sender sure looks like a oil pressure sending unit. Other than being shorter, the metal body part is the same shape, (socket wise), and the electrical plug in looks to be the same shape as an oil sending unit.
My 89 TPI 305, (Trans Am), has the oil pressure sender in that location but the sending unit itself is considerably longer.
Old Apr 8, 2013 | 03:57 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
the metal body part is the same shape, and the electrical plug in looks to be the same shape as an oil sending unit. .
Pic is of a 3rd Gen to show the location.Vettes have all the oil switches / senders behind the dist leaving
that port free for the oil temp sender
There have been a multitude of different style / configuration oil units for GM cars
http://www.motorcityreman.com/generalmotors14.html
FYI
81-89 1 wire oil temp unit
https://pontiworld.com.au/usgmsp/pro...388e04a895fe8f
90 -96 units have 3 wires for feedback to the ECM to calculate the "change oil " light
Old Apr 8, 2013 | 11:33 AM
TFS355S10's Avatar
Ah, I see now.
I'd never seen that short style 3 wire press sending unit. Mine has the huge long one. But I see the short one came on the Berettas too, and it just so happens I have one of those sitting in the driveway getting ready to go to scrap. LOL I'll have to look at the sending unit in it before it leaves, just to test fit it in my truck. I need all the room I can get... LOL
Good info vetteoz.
Old Apr 9, 2013 | 12:21 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I thought that was the oil pressure switch for the fuel pump.
Why would vettes have an oil temp sending unit? Does it tell the computer something, is there a gauge?
Not doubting you, I have no experience with vettes, just curious.
Old Apr 9, 2013 | 05:23 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by Johnny Blaze
Why would vettes have an oil temp sending unit? is there a gauge?
Yes
As noted above , on '90 + cars the ECM uses the oil temp as part of it's calculations for displaying the "Change Oil" light
I thought that was the oil pressure switch for the fuel pump..
As noted , always mounted behind the dist on C4's, not above the filter as done on 3rd Gens
Pre '88 cars had a separate pump switch and gauge sender; later cars had the large 3 wire combined unit shown
Old Apr 10, 2013 | 09:41 AM
Car: 1971 Camaro
Engine: 427
Thanks for the info! I never knew!
Old May 19, 2013 | 08:12 PM
nickynick17's Avatar
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
So for a firebird owner, could it be possible to put a T-fitting where the oil pressure sender is and also hook up the oil temp sender unit?
Old May 19, 2013 | 08:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Anything is possible but you would get a more accurate temp reading with the sender directly into the flow of the oil gallery of the block ;
not standing outboard in the breeze ( cooling off ) on a T fitting
Old May 19, 2013 | 09:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Go to the hardware store and get some 1/8 npt fittings.
Old May 21, 2013 | 08:42 PM
Engine: 350 TPI L98
Axle/Gears: 3.91
This is a good point haha, one more thing since vettes have the oil pressure switch mounted on the back of the block near the distributor, what does that port do for f-body applications? or is it just blocked off?
Old May 21, 2013 | 08:54 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
MY GTA has the oil pressure sender behind the distributor. When I changed my motor mounts I knocked the wire off getting the motor high enough and my gauge quit working.
Old May 21, 2013 | 08:59 PM
Engine: 350 TPI L98
Axle/Gears: 3.91
Hmmm thats interesting because on my Formula the oil pressure sender is located just above the oil filter
Old May 21, 2013 | 09:01 PM
rawley2's Avatar
I do have the oil cooler (warmer) on my car so maybe that has something to do with it.
I should also add mine just has one wire with a spade connector. If I remember correctly I think the wire was orange.
Old May 21, 2013 | 09:03 PM
Engine: 350 TPI L98
Axle/Gears: 3.91
Hmmm maybe because its a GTA and they had more options
Old May 21, 2013 | 09:11 PM
rawley2's Avatar
Dont know but I do have a digital dash if that means anything.
Old May 21, 2013 | 09:14 PM
Engine: 350 TPI L98
Axle/Gears: 3.91
Yeah probably, since the vettes had digital dashes they used oil temp to let the computer know when to flash the "change the oil" light on the dash
Old May 22, 2013 | 12:13 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Only for '90 +
The all C4's had a standalone oil temp gauge as I noted above
Old May 22, 2013 | 08:41 AM
rawley2's Avatar
Only for '90 +
I think what we are getting out of this is we have 2 places to tap in for oil pressure or temp.
I know all the earlier SBC pulled the pressure from behind the distributor like my 87 is.
You can use a T for pressure and put your temp in the other place. Just don't block the passage off by putting it to deep!!
Old Aug 29, 2013 | 07:30 AM
vandev1's Avatar
Car: 1985 Trans Am
Engine: swapped 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GW6 - 3.27 ratio
My '85 GTA with a 350 swapped for the original 305 has the oil pressure sender (single spade connector) behind the distributor going to the rally gauges. I'm not sure if there is an oil temp sender or where that signal would go on my car. I replaced the oil pressure sender when I bought the car and the dash gauge magically started working. Simplest fix I've done so far.
Side note, the rally temperature gauge goes to the cylinder head temp sender on the block (forward driver's side) above the exhaust manifold. Look for the cracked/melted (green?) wire.
Now I'm curious if I have another disconnected sensor hiding somewhere... The block temp seems to get warm on those summer hauls up out of the 120* heat of Phoenix with the A/C going full blast to stay alive. I've been contemplating adding an oil cooler to help her beat the heat on the highway. Knowing the oil temp would be useful and feed my OCD need to know exactly what my engine is doing at all times.
Old Aug 29, 2013 | 08:00 AM
Msaby's Avatar
I ended up installing the sensor in the oil pan and it works perfectly
Mike
Old Oct 26, 2017 | 09:38 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Mike
Older post, but could you throw up a picture of where you installed it? or did you just install it in the oil plug location?
Old Oct 26, 2017 | 04:05 PM
Twin_Turbo's Avatar
Here's how I did it. Mech gauge btw
https://photos.app.goo.gl/tpxoWTbEsRTkCs0H3
Old Oct 3, 2020 | 12:04 AM
Hawkeye1980's Avatar
Engine: 5.7
Axle/Gears: Stock
Hey Twin_Turbo. I am going to put in a mech. oil temp gauge in my bird. Its an Autometer. The tube that looks bolted to your oil pan, looks like a white plastic seal...where did you get that please? thanks
Old Oct 6, 2020 | 04:42 PM
Twin_Turbo's Avatar
Regular replacement oil drain washer seal
Old Oct 7, 2020 | 10:26 PM
Engine: 5.7
Axle/Gears: Stock
NICE Thanks for getting back to me. Thats what I will to. But what is the part coming out of the pan please? Looks like a metal drain neck (for lack of a better description on my part)
Old Oct 19, 2020 | 01:22 PM
Twin_Turbo's Avatar
I fabbed it myself.
aammcc
Jan 20, 2010 04:54 AM
nascarfan7
Dec 25, 2009 07:39 PM
BenDoe91z28
Sep 11, 2005 09:56 PM
EvilCartman
Dec 24, 2003 11:40 AM
Bunker82
Jul 23, 2002 12:05 AM
