missing on driver side only
Old Jun 18, 2013 | 12:41 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
I've checked plugs cap wires adjusted lifters New control module New pick up coil did a compression test checked the injectors there pulsing anymore things I can check let me know thanks
Old Jun 18, 2013 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: missing on driver side only
Doing a cylinder drop will be a quick way to find the cylinder missing. Even if a injector is pulsing and has good coil resistance does not mean the filter basket or there could be crud in the pintle causing a lean miss.
Old Jun 18, 2013 | 01:01 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
How u do a cylinder drop never herd of it
Old Jun 18, 2013 | 01:07 PM
Engine: Lb9
Transmission: M20
While the engin is running use spark plug pliers and start pulling the plug wires off on 1,3,5&7 Each cylinder will drop about the same rpm. You are just pulling the wire off and reinstalling it. When you pull off the cylinder having the miss there will be no change. This can be done at the cap or the plug side.
Old Jun 18, 2013 | 01:25 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
I've pulled each one of them off like how u say and there's a drop in each one of them and there all sparking good and I've pulled each injector wire off and it changes the motor also
Old Jun 18, 2013 | 01:33 PM
Engine: Lb9
Transmission: M20
A infrared gun is another good tool the cylinder with the miss witch sounds like a lean miss so it is still firing will run hotter. You never stated how you were able to figure out it was on the drivers side or if you have ohmed the spark plug wires.
Old Jun 18, 2013 | 02:35 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
I've got a heat gun and ive got true duels its.popping out the exhaust
Old Jun 18, 2013 | 06:01 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
I checked the driver side with the heat gun and 1 5 7 is 450 about and 2 3 4 6 8. Is about 360 about so that would be my injectors wouldent it be goin bad
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
GVMV
Aug 16, 2015 07:08 PM
Street Lethal
Aug 14, 2015 08:25 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
