People with a tpi and a engine with more than 350ci's
Old Jun 30, 2013 | 07:05 PM
school boy's Avatar
Just seeing how many people with big small-blocks still using a tune port. Wanted to get an idea of what you did to get what? Any who, heres my 406 tpi build going in my 86 c10 truck.
https://www.thirdgen.org/forums/tpi/...pi-86-c10.html
Old Jun 30, 2013 | 08:53 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: People with a tpi and a engine with more than 350ci's
I think this intake comparison
http://xtremecarzone.com.au/index.php?showtopic=386
accurately reflects what happens when you put the "designed for a 305 " TPI intake on a big cube engine.
TPI is fine for bottom end , stump pulling ,torque but you are leaving a lot of potential Hp behind.
Horse for courses
Old Jun 30, 2013 | 09:32 PM
school boy's Avatar
thanks vetteoz! been looking for a copy of that article! I agree im leaving a lot of hp on the table with the tpi. I was looking for big block torque and fuel injection for the mileage and sak of tuning. I was looking at a 350 when I stumbled across the 400 sbc. Just seeing if any more builds like this out there.
Old Jul 2, 2013 | 12:10 PM
school boy's Avatar
Anybody?
Old Jul 2, 2013 | 01:33 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
I have a 355. This is on top of it.
Old Jul 2, 2013 | 09:05 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Axle/Gears: D44 3.33 gears
383 TPI, lpe 219 cam, TPIS 113s.
[IMG][/IMG]
Old Jul 3, 2013 | 09:12 AM
school boy's Avatar
tpivette, how does it pull through the rpm's?
Old Jul 3, 2013 | 11:53 AM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
Much better than I would have thought. On the dyno it was north of 300rwhp all the way past 6k and it was relatively flat from 3.5k until we cut it off at 6k.
The torque however dropped off quickly, in typical TPI fashion. It started strong at over 450ft/lbs at 3400 rpm, but it dropped to 300ft/lbs by 5500.
Disregard the run-out after 6k.
Keep in mind this was a low budget build. I have around 4k in the engine including tuning.
Old Jul 3, 2013 | 08:53 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
forged 355, FIRST tpi intake, gm hotcam, worked over l98 heads full boltons and suspension...
pulls hard all the way up to 6 grand...... MUCH better mid and upper range power.... the best thing about the intake it flows better than and superram and hsr but looks almost stock.....
Old Jul 4, 2013 | 09:52 AM
school boy's Avatar
Thanks guys for the replies! tpivette, thanks for the graph!
Old Jul 5, 2013 | 03:25 PM
GenX'Motorsport's Avatar
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
TPIvette, Is youre TPI all stock? Looks like stock runners?
Old Jul 5, 2013 | 04:57 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
AS&M runners, ported plenum and an Accel base.
Old Jul 5, 2013 | 05:01 PM
actarnoff's Avatar
Engine: 355 TPI
Did you have any trouble getting them to seal? My runners wouldn't seal properly causing a massive vacuum leak. We had to put two gaskets on one side and one gasket + RTV on the other.
Old Jul 6, 2013 | 07:39 AM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
I've had the runners for 10+ years and I've had them on/off multiple times on two different engines and I've never had a problem with them sealing. Maybe I got lucky with a good set?
Old Jul 7, 2013 | 05:48 AM
wulff's Avatar
Car: 1987 Monte Carlo SS
Engine: 406 TPI
Transmission: T56 6-speed
My sig shows it all, I wanted a torque motor and that is what I got, AMAZING on the street, it shocks anyone that rides in it... some much fun compared to the L69 and 200r4!
Old Jul 7, 2013 | 07:18 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Nice, Tuned Port Injection in a Monte SS, that is the way it should have been from the factory. Throw some pictures up if you can, and possibly some video if you have...
Old Jul 7, 2013 | 09:48 AM
school boy's Avatar
Wulff, thats exactly what i like to see! Good to hear it works great!
Old Jul 7, 2013 | 12:39 PM
I see alot of of Monte SS's at local car shows with TPI motors. They really look great in the engine bay. Especially when done right and clean.
Old Jul 7, 2013 | 05:13 PM
TPIVette's Avatar
Car: 1991 Corvette
Engine: 383 TPI
I always wondered why GM didn't throw a TPI engine into the Monte Carlo SS. The GN/Turbo-T cars got a hopped up engine so I don't see why the Monte couldn't have gotten something a little better then it ended up with.
Old Jul 7, 2013 | 05:48 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I have a 383 in my Iroc and decided with the SuperRam. It pulls to ~5200rpms if I remember correctly.
Old Jul 8, 2013 | 10:12 PM
wulff's Avatar
Engine: 406 TPI
Thanks guys, I could never figure out why the Monte Carlo SS didn't get a 350 with a TPI from the factory. When I ordered mine new (yup I'm the original owner) I thought maybe I could find some secret box to check off and get a TPI but no.. LOL!
I will clean the motor and get some photos up soon. I do have a video I me running on a side street then pulling down onto the Interstate running through all 6-gears with a little fishtailing in 3rd gear that I like. I will try to get that up as well.
At the time I read that some of the Monte Carlo SS engineers really fought to have the TPI and a manual transmission installed but was told the F-bodys and the Corvette was enough.
You guys have some really great looking TPI motors, I don't think there is a more beautiful motor than a SBC with a TPI!
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
