1989 Iroc rare tpi option atach help me
Old Jul 28, 2013 | 01:14 PM
Camaropr's Avatar
Car: Camaro Iroc 1989
Engine: 5.7 Tpi
Axle/Gears: 2.72 9 Bolt Australian
Recently bought a 1989 Camaro Iroc 5.7 TPI with Bose package options and differential australian 2.72 9 Bolt and the plenum has an attachment which you will not, if anyone knows it please let me know. I would think that is in cold start injector. Thanks, Look at the picture.
Old Jul 28, 2013 | 01:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1989 Iroc rare tpi option atach help me
That looks like a ninth injector for sure. Looks like someone added it from a different application. The letters broadcast code on the computers memcal may tell another story.
Old Jul 28, 2013 | 02:07 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Where does the other side of that hose go?
Old Jul 28, 2013 | 05:18 PM
Engine: Lb9
Transmission: M20
From the fuel rail with a banjo fitting to a injector mounted onto the plenum.
Old Jul 28, 2013 | 05:47 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
That is not factory on any GM TPI Engine I have ever seen, and I have seen underhood of several hundred original and modified cars.
It is not an 88 and earlier cold start injector, either, as they were not in that configuration. 89+ cars did not have the 9th injector.
Old Jul 28, 2013 | 09:22 PM
Camaropr's Avatar
Engine: 5.7 Tpi
Thanks for your attention, is there any reason or advantage which he installed a ninth injector? and is not dangerous to send gas to the plenum?
Old Jul 29, 2013 | 12:28 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It could be a NOS nozzle for extra fuel or even for a old blower or turbo kit. Kick it on when boost is boosting or the spray is spraying.
Old school stuff from back in my day..
Old Jul 29, 2013 | 10:16 AM
Big&BadGTA's Avatar
I suspect it was driven off the throttle position sensor, or some other controller, activating the flow of fuel at (or between) a certain RPM. Maybe the car was supercharged or turbocharged, otherwise, I am not sure why it would be there, as running richer does not equate to performance.
kyleb24
Aug 15, 2015 08:24 AM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
