do corvette intake manifolds fit L98?
may seem like a stupid question, but i thought i heard once before that the stock corvette manifold wont fit on camaro or firebird L98. was looking at getting this to port / polish until i can afford an Edelbrock Hi-flow manifold
http://www.ebay.com/itm/350-c-i-L98-TPI-Intake-Manifold-for-small-block-Chevy-/131093087487?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e85c1c4ff&vxp=mtr
Middle intake bolts are 90 deg not 73 but can be made to work.
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: do corvette intake manifolds fit L98?
If it's easier for you, I have an '87 TPI manifold left over from my Vortec swap. You can have it for $75 shipped. Just PM me if interested.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I would port a stock base or go with a hsr before I would ever buy a edlelpoop !
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Vette fuel lines come in on the pass side not sure if the Fbodys are different. Youll have to do a whole lot of grinding to get a stock to do what the aftermarkets do out of the box.
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Your going to have to modify the EGR system if you have emissions inspections in your area. The vette pulled the exhaust through a tube on the passanger exhaust manifold instead of from the crossover in the head like the camaros.
Engine: Lb9
Transmission: M20
Emissions are disabled in his calibration, the vette intake has a second feed through the rh head so it would depend on the heads but it doesn't apply here.
i wound up not buying it. i was too conflicted between porting a stock intake out and getting an edelbrock intake....is it worth the money?
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
