Installing used injectors?
Old Mar 12, 2014 | 03:46 PM
Mason_99's Avatar
Car: 1985 Camaro IROC-Z
Engine: LB9
Axle/Gears: 10 Bolt, 3.42 gears
I just bought an '87 IROC TPI 350. It has an issue with running rich and the plugs getting wet with fuel. I'm thinking I could possibly have some leaky injectors. I have a set of injectors for a lower mileage '87 Corvette that have been sitting out if the car for a few years. Is there anything I should do to the as far as cleaning or anything or just put them in and see what I've got?
Old Mar 13, 2014 | 08:07 AM
southbay08's Avatar
Re: Installing used injectors?
my guess is that they are "shot". Get an ohm meter and check the resistance. Although they should be checked both hot and cold, this will at least give you an idea if the coils have some life in them at all. As far as cleaning stock multecs that have been sitting for a few years yourself.....Good luck!
Old Mar 14, 2014 | 07:03 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I wouldn't waste my time on them. They are probably stuck and are likely bad or soon will be if they are like the stock TPI injectors that came with your car. Plus, a set of remanned and flow tested injectors is fairly inexpensive considering the amount of work involved to change them. Besides leaking, the stock injectors like to short out when hot and shut the ECM down like you ran out of gas or have an ignition failure of some sort. No fun getting stranded, trust me I know. It only takes one bad injector to do it to you.
Old Mar 14, 2014 | 08:08 AM
southbay08's Avatar
Exactly!
wanted to say the same thing just didn't want it to sound like a sales pitch.
Mason_99 Afermont is absolutely correct.!
Old Mar 14, 2014 | 08:21 PM
Mason_99's Avatar
Engine: LB9
Are the screens you can see when you look down in the top of the injector replaceable?
Also I have a set of Bosch style 28 lb. injectors out of an LS1, can I use those in the L98 and if so would the extra lbs. cause any problems?
Old Mar 14, 2014 | 10:10 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Yes without a tune
Old Mar 14, 2014 | 10:17 PM
southbay08's Avatar
yes you need to make accommodations for the increase in fuel. will need a tune
Old Mar 15, 2014 | 06:47 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
I appreciate your efforts to be frugal, and to use what you have on hand(I am the same way).
But, with the low cost of the quality injectors Southbay sells, combined with the amount of work it takes to install injectors, there really is no reason not to put new ones in.
Old Mar 15, 2014 | 02:39 PM
Mason_99's Avatar
Engine: LB9
Wow I just checked out South Bays website and those are really good prices. I think I'll have to buy a set of those. Should I get the 22 or 24 lb. injectors?
Old Mar 16, 2014 | 08:17 AM
southbay08's Avatar
If everything is stock just stick with the 22's
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Firechicken86
Aug 12, 2015 10:07 PM
