TPI running sooo rich
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
well, here i go again.after spending the equivilant of what it costs to buy a new toyota on my 86 Z-28.im right back where i started. plug in the MAF and the car will barely start,and when it does. it is rich beyond belief,black smoke stinking like raw gas ect.unplug the MAF and it runs much better,but obviously not correct.every last part is new under the hood including the NEW MAF sensor from GM @ $1000.all the relays are also GM and new ad nauseum. on and on .new engine,injectors,regulator,throttle body ,TPS,IAC,temp sensor no vac leaks. yadda yadda.bought a FSM and followed the trouble tree for no results what so ever.i really dont want the car if i have to rip everything out and just go get a carb.anyone else have any ideas?? i would really like to keep and drive it. but not if all i can get for my $8000 is close. HELP ,SOMEBODY ANYBODY HELP!!!!!!
Re: TPI running sooo rich
sounds like the only thing you havent investigated is the EGR....isnt its sole purpose to burn off any remaining fuel or emissions? also what about O2 sensor? from what youre describing, something would seem to be telling the car to pump wayy too much fuel into the car and it sounds almost lke the MAF is a main proponent
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 86 IROC
Engine: 5.0 TPI
Engine: 4++,350 & 305 CIs
Check the vacuum line from the fuel psi regulator for raw fuel.
What injs are in the car?
Cheaper places to get a GM/Bosch maf.
Car: 86 IROC
Engine: 5.0 TPI
the injectors are from AZ and they OHM correctly the fuel pressure diaphram is from oreilleys and it does not have fuel in the vac hose. see gentlemen,, all those "easy" fixes have been checked to death. as i have been fighting this battle since 2009.
Have you checked the injs to make sure they are holding fuel PSI and not bleeding by?
Sounds like you have found the problem with the MAF but are in MAF denial like we all have been...
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I would like to know what the coolant temp sensor is reading the one for the ecm
Car: 82 Z28
Transmission: T400
A code is for a problem SOMEWHERE in a system ; not that just the item of that system is bad.
Need to work through the diagnostics , could be a wiring or ground problem
especially as you have both high and low MAF fault codes
http://www.chevythunder.com/maf_code_33.htm
http://www.chevythunder.com/maf_code_34.htm
Car: 86 IROC
Engine: 5.0 TPI
Car: 82 Z28
Transmission: T400
The ECM "expects " certain inputs on a system under certain conditions and if it doesn't see them as it should it tells you there is a fault somewhere in the system
Hence the flow chart to identify the actual problem so you don't throw $$$ at it in the hope of randomly fixing it
Car: 86 IROC
Engine: 5.0 TPI
Car: 1991 Z28
Engine: 350 tpi
Transmission: auto/stock
Axle/Gears: stock
mine runs rich also.. but not to the extent you are talking about.. but I can smell the exhaust and it's very rich and I'm sick of smelling it.. not to mention when I fill up the gas tank it smells like it's leaking.. I think that subsides when the gas is lower or over time.. I don't know but it makes me sick..
Sanjay
Aug 12, 2015 03:41 PM
