EGR check engine light
Old May 19, 2014 | 07:35 PM
NickDash's Avatar
Car: 1985 z28
My air pump has been deleted by previous owner causing my check engine light to come on when cruising at highway speeds. I been looking around and most people say I need to get a chip burnt to keep the light from coming on. Anyone know of a place to get one for cheap or a cheaper fix?
Old May 19, 2014 | 08:34 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
Re: EGR check engine light
your air pump is not related to your EGR... but still needs to be zeroed out in a chip... i'm sure there's guys on this site that will do that for you, for a price of course
Old May 19, 2014 | 08:50 PM
NickDash's Avatar
Car: 1985 z28
my check engine light comes on and it says EGR. My EGR is connected and assumed to be fine. My air pump is disconnected.
Old May 19, 2014 | 08:57 PM
Car: 1987 IROC Z28
so u grounded the aldl and what code did u get...
if your air system is removed and your chip isn't reprogrammed to reflect this change, it will throw a code. A.I.R system is different than your EGR
Old May 20, 2014 | 01:09 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Deleted smog pump will not set a code. These cars do not monitor A.I.R. function.
Old May 20, 2014 | 07:26 AM
Car: 1987 IROC Z28
couldn't the o2 sensor be expecting more oxygen in the exhaust stream and over compensate? obviously that wouldn't set off the EGR code... but thanks for the clarification
Old May 20, 2014 | 08:04 AM
NickDash's Avatar
Car: 1985 z28
The only code that comes up is a code for what the scanner says is EGR I cant remember the number. Ill have to run it again
Old May 20, 2014 | 08:08 AM
Car: 1987 IROC Z28
you have an OBD1 scanner?
Old May 20, 2014 | 01:48 PM
NickDash's Avatar
Car: 1985 z28
my uncle has a scanner for obd1 and 2
Old May 20, 2014 | 08:58 PM
NickDash's Avatar
Car: 1985 z28
So replace EGR then since air pump doesn't throw code? I just thought the two were connected.
Old May 20, 2014 | 09:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by NickDash
So replace EGR then .
No
Do the EGR diagnostics 1st.
read
http://www.chevythunder.com/egr_code_32.htm
Could well be a wiring or EGR temp sensor problem as much as or more likely than a EGR valve problem
Old May 21, 2014 | 10:10 AM
NickDash's Avatar
Car: 1985 z28
Thanks^
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
