CODE 45? Completely lost!
Old Aug 21, 2014 | 08:10 PM
MattGibson1's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
89 Iroc 305tpi. Car has new MAF and O2. I keep getting code 45 after the car warms up. I've had multiple o2's on it and still code 45. After it gets the code the car runs very rich and bogs down is almost impossible to start. Any ideas? I figured o2 until I changed it now I'm lost. I've even disconnected the battery but the code comes right back.
Old Aug 22, 2014 | 03:53 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: CODE 45? Completely lost!
did it run ok BEFORE the new MAF? are you sure you got a NEW MAF? it wasn't a auto zone "cardone special" was it? I had this same issue for more than a year till I finally got wise and bought a NEW MAF. yeah pig rich, code 45 BS.
Old Aug 22, 2014 | 07:16 AM
Engine: 5.0
Axle/Gears: stock
The car ran like garbage before the MAF. And it is a used bosch unit. The MAF definitely made a huge difference. Also I'm getting about 165 miles per tank of gas. So something has to be wrong.
Old Aug 22, 2014 | 11:33 AM
Car: 86 IROC
Engine: 5.0 TPI
the MAF has EVERYTHING to do with fuel flow. im not saying that your used one is bad. but I suspect that it MAY be. your fuel regulator diaphragm being bad will also feed un metered fuel into the system. I suggest a pressure test to confirm.
Old Aug 22, 2014 | 12:28 PM
Engine: 5.0
Axle/Gears: stock
I believe that MAF has a 1 year warranty so I definitely need to put on another to see what it'll do. I got code 45 again today. No clue why. This is the 3rd o2 in about 2 months.
Old Aug 22, 2014 | 12:32 PM
Engine: 5.0
Axle/Gears: stock
All 3 times I changed the o2 it was very burnt.
Old Aug 22, 2014 | 02:22 PM
Car: 86 IROC
Engine: 5.0 TPI
too much fuel will overheat and burn up a o2 sensor.(ask me how I found THAT out).have you confirmed the MAF you bought was a. . . . .ahem. re man one? where did you buy it,may I ask? if you bought a re man .THERES your problem. I bought SEVEN of them ,dude.from various places. and im here to tell ya. there are NO re man ones worth the box theyre in. I found that theres only one company that re builds them "cardone"regardless what the box says, and they all are from CHINA. I had your same BS problem for ever .till I went to oreilleys and bought a NEW one made by a company called "RICH_PORTER". and although it cost $450. it DID once and for all fix it. now it just plain works. keep at it ,do a fuel pressure test, and look for fuel in the regulator to plenum hose. it CAN be done .you CAN fix it. although ,you may be damn near broke AND crazy by the time you do. good luck,bro.
Old Oct 6, 2014 | 12:47 PM
HighPressure's Avatar
Car: Pontiac Firebird ´87
Engine: L69 305
..any news? Found the problem?
I just got exact the same problems but I've got a cc quadrajet and not a TPI.
Old Sep 7, 2017 | 08:16 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
So many of these stinking threads, the OP just disappears. It would be nice if there was some freaking follow up after getting help.
Old Sep 7, 2017 | 12:53 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
No doubt, the OP "dropped an LS in it" and problem-solved.
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
KO1
Aug 31, 2015 06:31 PM
2QUIK4U
Aug 26, 2015 04:40 PM
