question on installing new injectior leads
Old Aug 21, 2014 | 08:55 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Does it matter which wire goes to which? these are both white.
Old Aug 22, 2014 | 03:58 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: question on installing new injectior leads
Attachment 281832
yes absolutely. it matters. OR you could just get the CORRECT leads and toss that generic stuff.
Old Aug 22, 2014 | 06:52 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'm not sure if you'd consider ACDelco leads generic, but they have 2 white wires also. I'm guessing they just go with white since these pigtails are universal for many different cars. Hawks sells the color coded ones if you want to go that route.
Old Aug 22, 2014 | 11:06 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The injector is basically a 12v dc solenoid, right? I can't see swapping leads making any difference?
Old Aug 22, 2014 | 11:55 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Old Aug 22, 2014 | 02:07 PM
Car: 86 IROC
Engine: 5.0 TPI
you can consider them "AC china".and if you could swap the wires the FSM wouldn't specifically have a wiring diagram that clearly states that they have a signal and ground path. its not something to play around with.
Old Aug 22, 2014 | 02:13 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Well aside from generic-white or OEM-colored pigtails...you should be able to figure out which lead goes to what terminal by looking at the original.
Old Aug 22, 2014 | 02:26 PM
Car: 86 IROC
Engine: 5.0 TPI
yeah it aint hard. I just am not pleased with the fact that its hard to get pigtails with the correct color wires. hell, some of the pigtails don't even have the correct gauge wires. I guess its all about CHEEP now days.
Old Aug 23, 2014 | 05:06 AM
aramirez121's Avatar
Car: 1991 camaro rs v6
Engine: v6 3.1
Transmission: auto
are there any colored lines on the wire
Old Aug 23, 2014 | 09:44 PM
mjdavis68's Avatar
Generic or not , i'm at least trying to save one of these cars..
The wire just has brand of wire but i can figure it out , thanks for all your help guys
Old Aug 24, 2014 | 06:46 AM
Car: 86 IROC
Engine: 5.0 TPI
props to you for that man, I wasn't bitchin at YOU . I just hate the fact that when you DO try to fix one of these ,you find that either the parts you need are no longer to be had. OR when you do get them they somehow have been modified. I too saved my 86 IROC from the crusher. got it in 09 and I know the struggle well. anyway, hats off to you
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
