1991 TPI Hard starting???
Old May 25, 2015 | 01:39 PM
91iroc's Avatar
Car: 1991 Z28 CONVERTIBLE
Engine: SUPERCHARGED 5.0
Transmission: AUTO
Hi guys, just having real issues trying to figure this out.
I am driving 1991 z28 conv. 5.0 tpi automatic, everything stock platform.
It's having a hard timing starting, but it will start once I feather the throttle. If it warms up it will stay on but other wise die and continuously have hard to start issues. The car runs fine otherwise.
I check fuel pressure , I am getting spark, checked ohms on injectors and voltage to injectors, cleaned throttle body, base timing is 6 deg btdc.
I replaced distributor, idle air control valve, o2 sensor, control module, cap rotor, plugs , wires, coolant temp sensor, replace and checked tps, new battery, and starter.
Now what do I do ?
Old May 26, 2015 | 11:03 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: 1991 TPI Hard starting???
Any codes? Timing set correctly? When it doesn't want to start, does it turn over hard? Make any rude noises?
Old May 26, 2015 | 11:54 AM
91iroc's Avatar
Transmission: AUTO
Base timing is set at 6 degrees btdc. no codes, no check engine light, no extra noises, cranks over real nicely.
Old May 26, 2015 | 08:26 PM
Irocblast's Avatar
Car: 1987Iroc
Engine: 5.7
What is your fuel pressure? When was the last time fuel filter was changed? I would ensure fuel filter is not clogged by taking it off and trying to blow through it.What was the the Ohms resistance on the injectors? Just throwing it out there.
Old Jun 2, 2015 | 06:51 PM
91iroc's Avatar
Transmission: AUTO
i reset the IAC. car runs fine now , no issues
Old Jun 2, 2015 | 07:58 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
IAC?
Old Jun 2, 2015 | 08:15 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Idle air control valve
Old Jun 2, 2015 | 10:46 PM
91iroc's Avatar
Transmission: AUTO
Its doing it again. It ran fine for two days.
Old Jun 5, 2015 | 11:57 AM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Buddy, I recently had the SAME issue w/ my 92RS. I swapped out the Plugs & threw in a MSD Street-Fire Ignition Coil and BAM no more hard starting. Now addressing the fact we have to press the accelerator peddle....Im at a loss. your thoughts?!?
Old Jun 5, 2015 | 12:00 PM
Engine: 305 / 350
And help me understand how you Reset the IAC? I was only able to remove it and clean it w/ BPC or Carb Cleaner... It seemed to do the trick however I ran out of cleaner so the cleaning was half assed. I will be cleaning it fully this evening and will post an update. Let me know what you find...
Old Jun 5, 2015 | 04:21 PM
91iroc's Avatar
Transmission: AUTO
i guess i will replace the coil, but i am getting good fire.
Old Jun 5, 2015 | 04:24 PM
91iroc's Avatar
Transmission: AUTO
This will help on resetting iac
https://www.thirdgen.org/forums/tech-general-engine/179551-floating-idle.html#post1304610
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
