NEED SOME HELP WITH 92 GTA!
Old Dec 23, 2015 | 03:06 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys I have a 92 trans am with a 350 tpi. I decided to take the accel runners I had off and go back to stock. Car was running excellent I got everything put back together and it started to run horriable. I checked the codes and I get 22 33 and 34. The tps is new I've never had problems with it. And the map wad working fine before I tore it apart to get the runners off. I checked for vacum leaks and can't seem to find any. Anybody have any other suggestions.? Thank you
Old Dec 23, 2015 | 04:13 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: NEED SOME HELP WITH 92 GTA!
Vacuum leak shouldn't cause those three codes I wouldn't think. Pinched wires, bad/loose connector? I'd start ohm testing circuits and such.
http://chevythunder.com/fuel%20injec...g%20pg%20a.htm
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Dec 23, 2015 | 05:59 PM
Engine: 350 tpi
Awesome I'll start to check all the wiring tomorrow. Maybe I pinched a wire somewhere or something.
Old Dec 23, 2015 | 07:26 PM
Engine: 350 tpi
Also does anybody know where the map sensor vacum line goes too? I have it to the egr.?
Old Dec 23, 2015 | 09:19 PM
ULTM8Z's Avatar
MAP sensor can go to any constant vacuum source.
Old Dec 23, 2015 | 09:36 PM
Engine: 350 tpi
Ok so the egr should be good connected to the map?
Old Dec 23, 2015 | 09:56 PM
NO. The egr should be connected to the egr solenoid which should have vacuum sourced from the port under the TB. The MAP should be connected to a manifold vacuum source, the plenum should have a port right under the MAP specifically for the MAP. https://www.thirdgen.org/forums/tech...iagrams-i.html
Old Dec 24, 2015 | 01:27 PM
Engine: 350 tpi
So went outside and switched the vacum from the egr to the port to the plenum side and it seemed to work and I accidently pinched the blue wire to the tps when I was taking the runners out. Everything is back to normal no more codes thanks for all the help.
123pugsy
Dec 6, 2015 09:54 AM
punkmaster98
Exterior Parts for Sale
Dec 3, 2015 11:56 PM
bbsr72
Nov 13, 2015 08:21 AM
Aerizanthar
Nov 10, 2015 10:01 AM
Abubaca
Nov 6, 2015 05:24 AM
