TPI go fast tips and tricks?
Old Sep 17, 2018 | 01:27 PM
  #351
auto_god's Avatar
Car: 1991 Firebird Formula
Re: TPI go fast tips and tricks?
Originally Posted by VincentZ28
Hate to burst your bubble but someone put those pistons in your rebuilt engine. MAHLE only been around since 2005-2018.
https://www.mahle.com/en/about-mahle/mahle_chronicle_/
According to their website, Mahle was actually started in the 1930's.
Old Sep 19, 2018 | 08:54 AM
  #352
ray jr's Avatar
mahle pistons have been around for a long time .. probably close to 100 years
Old Sep 19, 2018 | 05:15 PM
  #353
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
But have they been found in stock motors?
Old Sep 19, 2018 | 06:49 PM
  #354
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
lol good question. I got a 91 305 set of pistons at home i will go inspect to see if there are any markings. My thoughts were if somebody supplied them to Gm then they would leave their mark off the piston but who knows
Old Sep 19, 2018 | 07:01 PM
  #355
auto_god's Avatar
I didn't come across anything during tear down that would lead me to believe that this motor was anything but all original.
Old Sep 22, 2018 | 10:26 AM
  #356
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Mahle was GMs piston manufacturer for a while. I have had pistons with the Mahle stampings that I found in LT1 and Vortec engines.
Old Sep 22, 2018 | 09:24 PM
  #357
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I just purchased, pulled and disassembled a mid to late 92 formula 350 engine today with mahle 4 eyebrow flattop pistons. Engine had never been apart before today. (Didn't have powdered metal rods)
A couple yrs ago I swapped a 305tpi oil pan on a good friends original very late 92 Trans am vert and it had powdered metal rods with mahle pistons. (Oil pan was rusting outside in)
Old Sep 24, 2018 | 11:14 AM
  #358
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
Originally Posted by Black00SS
Reminds me of a story.
I had a buddy, who's cousin SAW a G92 92 Z28 trapping 135 MPH BONE STOCK.
Track was at the top of Mt. Everest, cool breeze was blowing, the first 60' of the track was covered in stick em commonly used by NFL players in the 70s and 80s.
The same day (This was early 1993), a 2002 WS6, M6, cam/heads/nitrous and drag radials could not get out of the 17s to save his life. My great grandson (at the time, he has since passed....I am 34 now), was running 11.85-11.90s with his BONE STOCK 89 Formula 3.1. This car DID have the factory G92 option, with STOCK Formula 14x7 steel wheels, and 195/70r14 tires.
NOW, with all that being said, EVERYBODY knows these cars run MUCH better when nobody is actually recording the runs, and they cannot be documented in any way. Every Tom, Dick, and Harry knows the recording equipment causes an "Magneto from the X-Men" interference with the ECM.
Hell, my 17 Ram 1500 sport clicks off low 12s at 146 MPH until people start fing it up with recording equipment.
Final point: I know a guy, who knows a guy, who's nephew, has a buddy, with 365 NOS T-Rams, 117 Dana 44 rear axles, and 39 of the original 27 Firehawks....
You're hilarious man.
Old May 6, 2019 | 07:34 PM
  #359
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
Originally Posted by red rock
After a new tune up, plugs, dist cap, wires. Here is a list of some mods besides heads and cam of coarse. Throttle body coolant bypass (assuming you don't drive in cold weather), Move your MAT sensor to a cooler spot. Cooler thermostat, Custom tuned chip (delete EGR, AIR,VATS again, assuming you don't need emission inspection test), 1.6 roller rockers, adjustable FPR, Free flowing exhaust (headers), Free flowing intake mods. There are more that i can't think of, but these will keep the stock look you want.
I have done this with our 92 Z28 5.7 and would like a prom made, any suggestions?
Old May 8, 2019 | 12:22 PM
  #360
newbvetteguy's Avatar
Car: 1979 Corvette L82
Engine: Gen1 SBC 350 L82 4 bolt mains 010
Transmission: Monster 4L60e 2wd 1997 PWM capable
Axle/Gears: 355
This thread kinda scares me, but best go fast tips:
1. Address the exhaust
2. Add modern top-tier aluminum heads ($900-$1,600)
3. Replace air restrictor intake with FIRST Fuel Injection Intake ($1,050 complete)
4. Add Modern cam designed to take advantage of heads and FIRST intake
5. Upgrade injectors for your dramatically improved HP
6. Tune
OR:
2. ADD RCS Racing's 383 FIRST crate motor: 460 hp, 520 ft lbs: More HP and way more torque than a C5 Z06 Corvette, more HP and way more torque than a C6 LS3 Corvette (426 hp & 438 ft lbs with the optional performance exhaust) http://rcsracingengines.com/Perf%20C...evy%20EFI.html
3. Troll C5 Corvettes (Optional but highly encouraged)
Adam
Bowtieman1970
Aug 17, 2016 02:50 AM
Donniemoss86
Mar 22, 2016 10:37 PM
camaro1185
Mar 22, 2016 06:41 AM
chanrahan
Mar 21, 2016 09:53 PM
That Sky Guy
Mar 15, 2016 07:40 AM
