Oil pan help
Old Dec 29, 2001 | 12:20 PM
88IROCZ350's Avatar
Oil pan help
I am working on installing my procharger and i was wondering if it is very hard to just pull the oil pan, and then put a different fitting in so i don't have to punch a whole in the pan. I've read somewhere where someone did that but my question is how hard is it to pull the pan with the engine and everything in the car. Is it possible? Thanks for the help
Old Dec 31, 2001 | 01:20 PM
Tonyrodz's Avatar
Transmission: auto
oil pan
Once I tried to change my oil pump in an 85 Monte SS--it was impossible to do w/the engine in the car!! Tried everything--unbolted the motor mounts, jacked up the engine--took out all the bolts from the pan too! Not enough clearance for the pan to clear the crossmember.
Now I know this isn't the same kind of car--but it's a similar setup.
Good luck to you!
Old Dec 31, 2001 | 02:32 PM
Eighty5TransAm's Avatar
I found out how to drop the pan the hard way. I dropped a nut down my distrbutor hole while changing the heads. Had to un bolt the motor mounts and jack up the motor as much as i could. You may have to pull the distributor inorder to raise the front of the motor enough.
Hope that helps, Curtis
Old Dec 31, 2001 | 06:21 PM
a73camaro's Avatar
Hold the phone
Can't you just run you oil return to the fuel pump block off plate????
Old Jan 1, 2002 | 11:25 PM
BLWR PWR's Avatar
Car: 89 IROC
Engine: Built 383, Vortech SC
Transmission: Pro-Built 700R4
Axle/Gears: Dana 44, True Trac, 3.54
I have a Vortech. Very well put together kit, fit and finish was excellent. Yet for some reason they to have you punch a hole in the pan. Rinky, dink. It is not easy to do at all, from under the car, no clearence etc. I did it . It worked. Few months later we had the engine out and just for safety sake I added a Moroso oil pan(7qts with filter) and had a threaded bung welded in the pan for that return line. No more worries about leaks or lack of oil. Just food for thought.
Old Jan 2, 2002 | 03:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Someone just posted this on our email list..
http://www.spots.ab.ca/~jmd/pan.txt
It's do-able. The 3rd Gen F-body will be very similar to the Monte chassis.
Matthew
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
