Correct ignition coil???
Old Jun 14, 2018 | 12:48 PM
Go Blue's Avatar
I bought my 88 IROC 350 with this ignition coil. It seems to me that most of the ignition coils would have a regular plug (or 2) in it and not just 2 wires with eye terminals. Is this the correct ignition coil for my car??
Old Jun 14, 2018 | 12:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Correct ignition coil???
That was a old Accel replacement coil. The factory one had a black and grey plug.
Old Jun 14, 2018 | 01:00 PM
Go Blue's Avatar
That's what I figured. Guess i'm going to need to find some new wiring to make this right again. Darn it!
Old Jun 14, 2018 | 01:02 PM
Engine: Lb9
Transmission: M20
https://m.ebay.com/itm/Set-Connector...dcbe%7Ciid%3A1
Old Jun 14, 2018 | 01:03 PM
Go Blue's Avatar
Do you have the winning Illinois Lottery numbers too since this seems to be an "ask and I shall receive" type situation?? LOL
Old Jun 14, 2018 | 01:06 PM
Engine: Lb9
Transmission: M20
No but I can make up some numbers lol.
Iirc the grey body connector is the body side harness the black is a jumper to the icm from the coil.
https://m.ebay.com/itm/GM-TPI-TBI-HE...UAAOSwPe1ULCRQ
https://m.ebay.com/itm/87-95-LT1-TPI...sAAOSw5ZBWP75G
Old Jun 14, 2018 | 01:15 PM
PaulyC's Avatar
I believe they had an adapter that plugged into the factory harness connector too. Follow the two wires back and see if they actually used it. If they did all you need is the coil.
Old Jun 14, 2018 | 01:18 PM
Go Blue's Avatar
Thanks Pauly! I'll be able to do that tomorrow night or Saturday and trace it back. I tried to look at the base of the distributor to see the connectors but I wasn't able to see much of anything through the wires at the time I last tried.
Old Jun 14, 2018 | 02:50 PM
Abubaca's Avatar
I think that's backwards. Not SURE...gotta look and see tonight, but I think grey is the jumper to the ICM. I could be wrong....and ultimately I suppose you COULD wire it either way. But I think its the grey to the ICM.
Old Jun 14, 2018 | 03:14 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
And possibly the coil bracket, which is mounted to the rear of the intake manifold on the passenger's side, next to the distributor.
I'd bet they removed it. If not, maybe you'll luck out, and find everything you need right there.
Old Jun 16, 2018 | 10:32 PM
Go Blue's Avatar
Pauly,
good call! The original wires and connectors were still there. I was able to trace the wires back to the correct connectors. Now all I need is to figure out which MSD ignition coil to use and hopefully find an MSD ignition control module for my car. I’ve found Accel and a couple other manufacturers modules but not MSD.
Old Jun 17, 2018 | 07:37 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Here is the MSD Blaster coil that I used.
https://www.summitracing.com/parts/m...o/submodel/z28
You are right as I could not find a MSD ICM. I used all MSD parts for the rest of the ignition(cap, rotor. wires) and I decided to buy a Jegs brand ICM.
https://www.jegs.com/i/JEGS/555/40602/10002/-1
Akshay
Apr 29, 2002 10:16 AM
Akshay
Apr 21, 2002 02:43 AM
jfox55
Apr 8, 2002 05:49 PM
