TPI problems
Old Sep 4, 2018 | 08:13 PM
Logan Bryant's Avatar
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
TPI problems
Finally fixed my car for like a month and then back to having more problems with it. Have replaced so many parts on it. Car is an 85 305 tpi. All new tpi gaskets, new South bay 19 lb injectors, fuel pressure regulator diaphragm, IAC valve, egr valve and egr temperature sender. Also put a heated three wire ac delco 02 sensor on it. I uploaded the pictures of tuner pro data logging it. It seems that the o2 sensor isn't getting any voltage. Also the volt gauge on the gauge cluster hops around too. If you see anything else that is out of wack in the picture, leave it down there. Thanks
Attached Thumbnails TPI problems-20180904_202001.jpg   TPI problems-20180904_202122.jpg
Old Sep 4, 2018 | 08:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI problems
You might check the continuity on d7 of the ecm to the o2 .
Old Sep 5, 2018 | 07:54 PM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: TPI problems
How exactly do I do that?
Old Sep 5, 2018 | 08:04 PM
Engine: Lb9
Transmission: M20
Re: TPI problems
With a volt ohm meter
Old Sep 6, 2018 | 08:31 AM
Car: 1991 RS
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: TPI problems
Where is the D7 at though?
Old Sep 6, 2018 | 09:00 AM
Engine: Lb9
Transmission: M20
Re: TPI problems
At the ecm
Old Sep 6, 2018 | 09:08 AM
Engine: Lb9
Transmission: M20
Re: TPI problems
Old Sep 6, 2018 | 09:49 PM
FART_NUGGETS's Avatar
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
Re: TPI problems
Doing the Lord's work Mr. Tuned Performance...
this pic is going in my archive for when I need it.
ORANGE_PEEL
Apr 16, 2011 08:57 PM
Aggp18
Apr 3, 2005 05:40 PM
88irocz28
Sep 16, 2002 12:46 AM
oldblueZ
Jan 4, 2001 05:23 PM
oldblueZ
Jan 4, 2001 04:13 PM
