Lost power to the fuel pump??
Car: 87 IROC
Transmission: auto
So I've had the 91 running several times the past few weeks. Moved it around under it's own power in the shop. Buttoned up a couple odds and ends tonight and was gonna take it out and up the road and back. Went to start it and didn't hear the fuel pump prime. No power at plug above the driveshaft with key on. Have battery power to the relay. But i have no power from the drive wire from ecm. I started it last weekend for my kid to hear it run and fired right up. Really annoyed tonight! Where do i go next?
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Lost power to the fuel pump??
ECM provides ground path on the relay control circuit, doesn't it? With key on, you should have power at two points in the relay socket. (one is battery, the other should be switched ignition.)
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
G4
http://www.austinthirdgen.org/mkport..._1990_C100.gif
check your grounds behind the passengers side cylinder head.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
As shown below, for whatever reason GM brings the relay up for fuel pump, but almost every other relay down. Not sure why, but that banged me up when I made an engine harness for someone. Won't make that mistake again
Car: 87 IROC
Transmission: auto
Found my Haynes book and have that diagram. According to that there should be 12 volts coming from the ecm right? I have no power in that wire. Didn't yet pull the connector out to check it right off the ecm. Plan on doing that later tonight. I don't have, and haven't yet, had the ground wire from the engine to the firewall. Was just gonna run run from somewhere else on the engine. But it's been running like that for a couple weeks. The ground wire coming to the relay indicates good.
Car: 87 IROC
Transmission: auto
Don't laugh guys, found it
Upon further inspection, and applying the KISS theory... realized i hadn't screwed the 2 grounds to the fender by the fuel pump fuse!! Only had them stuck behind the fuse holder! Screwed them against the fender and boom, power!!
Upon further inspection, and applying the KISS theory... realized i hadn't screwed the 2 grounds to the fender by the fuel pump fuse!! Only had them stuck behind the fuse holder! Screwed them against the fender and boom, power!! Thread
hotrod9168
Jun 12, 2012 08:18 PM
84KYSS
Jul 4, 2008 09:15 AM
