water pump leak
Old May 18, 2019 | 10:57 AM
Mike69's Avatar
Car: Trans am GTA 1991
Engine: 5.7l
water pump leak
Hello,
I noticed a leak in my water pump. The liquid comes out of the small hole below on the pump body.
I think to disassemble it but do not really know what is the purpose of this hole and why all of a sudden the liquid comes out ...
Thank you in advance for your comments on this problem.
Mike
Old May 18, 2019 | 11:02 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: water pump leak
If coolant is coming out of the weep hole just replace the pump.
Old May 18, 2019 | 11:34 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: water pump leak
Old May 18, 2019 | 01:22 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Thank you for your answers .
So the pump is HS? This is not a story of seal or pump plugged?
I will buy a water pump, brand adelco on rockauto what do you think?
Thanks again
Mike
Old May 18, 2019 | 02:12 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
How much coolant is in the circuit?
This will help me when the water is returned ...
Is there a bleed screw on the circuit to chase the air?
Thank you
Mike
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: water pump leak
Thanks again
Mike
The pump is worn out; simply replace it. Buy a new, original equipment replacement if possible.
Old May 18, 2019 | 02:18 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Ok thanks, on which site can I find original parts?
Mike
Old May 19, 2019 | 02:33 AM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Hello,
I found for the quantity, 16.6 quarts it is 20 liters in France,
Ouah it changes our small French cars ...
Mike
Old May 19, 2019 | 04:44 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: water pump leak
Hello,
I ................................................. The liquid comes out of the small hole below on the pump body.
I think to disassemble it but do not really know what is the purpose of this hole .........................................................
Mike
The REASON w-pumps incorporate "weep holes" is to give the leaking fluid a place to go, when the shaft seal fails. Otherwise, the fluid would be forced into the outer shaft bearing, causing rapid, catastrophic failure.
Old May 19, 2019 | 04:56 AM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Thank you for the explanation, it's clear and precise. I understand why there is a leak ...
Mike
Old May 19, 2019 | 05:52 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: water pump leak
Your welcome, Mike69!
Old May 19, 2019 | 02:26 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Thank you ,Mikeceli ....
Old May 20, 2019 | 12:48 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Hi,
So I have disassembled my water pump this afternoon,on the other hand i removed only 10 liters (about 2 gallons instead of 4 I think) but I see that the ducts behind the pump are still full so the rest must be in the engine block. Anyway the liquid was clean more radiator should not be very old I feel that it has been changed so the cooling circuit had to be followed before.
More than waiting for the new pump ...
Thanks for your help
Mike
Old May 20, 2019 | 04:40 PM
88 TA's Avatar
Car: 88 T.A.
Re: water pump leak
Change your belt while you have it off. Check both radiator hoses for wear. It’s shouldnt cost much more to replace them and you won’t have to worry about them later.
Old May 30, 2019 | 08:31 AM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Hi
So water pump changed impeccable but I have only one fan on 2 turns to trigger apparently there is one that is not powered ...
No 12v on the connector
Do they rotate at the same time or one after the other?
Thank you
Mike
Old May 30, 2019 | 08:50 AM
88 TA's Avatar
Car: 88 T.A.
Re: water pump leak
2nd fan works with the air conditioner. There should be something plugged into it. It’s supposed to come on at higher temps.
Old May 30, 2019 | 09:25 AM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
This is what I had understood with the Technical Review it is used for air conditioning.
Otherwise as my air conditioning does not work is it that I can couple the 2 fans for better cooling?
Old May 30, 2019 | 09:39 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Re: water pump leak
Yes oem most definitely. I purchased a autozone duralast one and it wouldn't fit. Had to grind it down on the left side and right.
Old Jun 20, 2019 | 01:15 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
Hello,
Do you think it is possible to couple the 2 fans for better cooling as my air conditioning does not work?
In this period of heat, as soon as I am idling, the temperature rises high enough and quickly enough.
Thanks for your advices .
Mike
Old Jun 23, 2019 | 02:55 PM
Mike69's Avatar
Engine: 5.7l
Re: water pump leak
no one for an opinion?
Old Jun 23, 2019 | 06:32 PM
88 TA's Avatar
Car: 88 T.A.
Re: water pump leak
Not sure.how high is it going up
calgutie
Sep 2, 2012 10:45 AM
hydrolic144
Nov 11, 2010 05:20 PM
ATCharming
Jun 29, 2009 03:33 PM
jer8716
Sep 17, 2008 06:12 PM
steriko
Jan 10, 2005 12:44 PM
