No wide open throttle
Old May 30, 2020 | 08:36 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Hello all , having no wide open throttle response from my 91 Z/28 l98 new injectors and fuel pressure regulator fuel pump was replaced at some point by previous owner car will rev just fine in park but with a load on it in gear the car is non responsive
Old Jul 26, 2020 | 03:06 AM
jonny_sanchez99's Avatar
Car: 1991 camaro z28
Engine: SBC 355
Re: No wide open throttle
Sounds like some kind of transmission problem, since the engine revs just fine but once in gear it doesn't move at all.
Old Jul 26, 2020 | 07:45 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Does it go at all when put in gear? is it just @ WOT that it does not respond? Since the regulator was replaced you should start by using a gauge and check the fuel pressure when running. You can hook a gauge to the Schrader valve on the fuel rail and tape it to the windshield and drive. You should see about 35 PSI when idling and 43 PSI on the gauge when you accelerate in gear.
There are a few things that could cause this issue one of them is your ICM not advancing the timing. Before you go throwing a bunch of parts at this you will have to do some tests first.
banksGTA
Sep 13, 2015 11:56 AM
Corey.g
May 10, 2010 06:53 PM
thirdgennewie
Oct 20, 2009 06:57 PM
TransAm12sec
Mar 26, 2005 04:39 PM
Ann.racer92
Aug 13, 2004 03:12 PM
