Cold start injector...necessary?
I am transplanting a 1985 TPI engine/transmission into a 1955 Chevrolet build and have a question regarding the CSI and the potential possibility of disregarding it all together. I know the difficulty of finding one....when I got my injectors back from testing the CSI came back as "pulsed one time then quit...suggest replacing ". I planned on using a block-off plate and eliminating it, but the gentleman making me a Stage 2 Custom Chip doesn't think he can eliminate it on the 1985 ECM.
Question #2....with the chip programming the lock-up on the transmission, will I need to use a 4 terminal brake switch, or can I use the stock 2 terminal switch?
Any thoughts?
Mike
Any thoughts?
Mike
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cold start injector...necessary?
The csi help with cold start. But I wouldn’t waste a dime on using ghe870 ecm. Goto Larry’s electric and get a 1227730 speed density harness and ecm.
Mike
There is no significant support for using the 870 ECM from the 85 cars. So if you plan to use it then you will need to fix the CSI. If you want to switch over to the 165 ECM or the speed density 730 ECM then you can either burn a chip to delete the CSI or in the case of the 730 it already doesn't require it.
GD
GD
Engine: Lb9
Transmission: M20
As far as I know painless only makes a stand alone harness for tpi maf 1227165 ecm and 1227730 ecm. You might consult your instructions but I don’t think you can use your 85 870 ecm.
Mike
Engine: Lb9
Transmission: M20
That harness is for a 1227165 ecm. I’m not sure if the 85 maf sensor can be used. Could always give it a try . It’s considered digital and 86-89 uses analog. You should get a memcal programmed for 89 without vats.
this world not use the ninth injector. There are block off kits available on eBay or hawks thirdgen.
Painless was mistaken. That will not work with the 85 computer or MAF. You will need to get a 1227165 ECM, matching 86-89 MAF sensor, and as Tuned Performance mentioned you will need an 89 PROM chip or custom chip to delete the CSI.
It has the CSI injector provisions because those were used on 86-88 models as well as 85.
GD
GD
In my experience, the 1985-version FM output MAF cannot be used reliably with the analog input scheme used in the 1986-89 ECMs due primarily to linearity at the higher output end - The "dumb" input buffer cannot reliably translate thr FM output to the required analog voltage. You could build a rudimentary converter using a 0808 and divider to get the supply voltage to 5V (or a regulator IC), but it is probably just easier (and possibly cheaper) to get a later design analog MAF.
Once the MAF issue is resolved, the use or elimination of the CSI is easy, and well-documented here, many times.
Been there:
Been there:
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
You might want to look into dynamic EFI's flash. Setup it's the same harness as a '165 but allows you to eliminate the MAF and cold start.
or if you want I have my old '165 ( 88-5.7 Auto with 2:77) chip cheap. I probably have the old cold start stuff but would have to look for it.
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
Side note on the 9th injector. Since you have what looks to be a fair weather hobby car, you could probably block off the 9th injector and do nothing else. If you are not driving it in the cold, won't matter. One thing that didn't get touched on here, is the ECM does not control the 9th injector. It is only powered during cranking to give extra fuel when it is cold. The later cars just opened the cranking pulse width, Ideally you get a chip with the updated tables, but if you only drive in nice weather, you wouldn't notice it is gone.
The harness is wired for the CSI...what do I do with that connector? It is connected to the right side injectors.
Mike
It will, what it won't do is work with your ECM. I have went the EBL route as mentioned above. It was a lot easier than you would expect and allows you to do flash based tuning. This includes removing the 9th injector and the old MAF that like to go bad and cause code 36 frequently.
Mike
