Question about different Felpro intake gaskets
I have a question about the different gaskets. I see a 1204, 1205 Felpro intake gaskets. What exactly is the difference? And when should you use which gaskets? What would I use for my stock 91 tpi? Learning as I go.
Car: check
Engine: check
Transmission: check
Re: Question about different Felpro intake gaskets
The port opening size varies. The 1205 has a larger opening then the 1204. I don't recommend Fel-pro intake gaskets, especially the ones with the Printoseal. They move around.
Get some Victor Reinz (VR) gaskets that have a raised embossed area around the various ports.
RBob.
RBob.
RBob.
RBob.
of people love Fel-pro. But I bought some Victor Reinz gaskets for my intake runners. And the quality of them was great! And I noticed they had the raise area on them also.
delete
Transmission: Pro-built 700R4
Car: check
Engine: check
Transmission: check
I'm in the process of installing an Edelbrock intake. Would those fit the ports?
I found those gaskets on Autozone's website as well as eBay, but for some reason both of them say that they won't fit my car. Any ideas why, or is their information wrong? Sorry for badgering you on this topic. I just want to make sure I get the correct ones.
Car: check
Engine: check
Transmission: check
Because Vortec heads have the mounting holes in a different location?
Or, stock '92 SBC heads have the four inner bolt holes in a different location?
RBob.
RBob.
These are for my '92 T/A with stock heads, not the '91 GTA that has the vortec heads. Sorry for the confusion.
