305 tpi will not rev past idel
Old Jun 19, 2021 | 09:08 PM
vandiemen17's Avatar
Car: 87 Trans Am
Transmission: T-5 World Class
My 87 Trans Am 305 TPI idles fine, starts right up. Drops off at any throttle position. Changed MAF, TPS, Fuel Pressure Sensor, Distributor Cap, Rotor, Plugs Wires, Fuel Pump, Fuel Filter, and all Vacuum Lines. I am at a loss. HELP
Old Jun 20, 2021 | 05:59 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: 305 tpi will not rev past idel
Have you changed the ICM? It located at the bottom of the distributor and it controls the spark advance..
Old Jun 20, 2021 | 06:54 AM
Car: 87 Trans Am
ICM is new also. The more I work on this the worse it runs.
Old Jun 20, 2021 | 02:10 PM
Vader's Avatar
Fuel pressure sensor? Di you mean to report regulator? There is no pressure sensor on the vehicle, and they didn't appear until the mid/late 2000's on a few vehicle models.
Speaking of fuel pressure, can you report the pressure measurements?
Old Jun 20, 2021 | 06:19 PM
Car: 87 Trans Am
You are correct fuel pressure regulator. Pressure is 40 to 45 psi.
Old Jun 22, 2021 | 09:20 PM
Car: 87 Trans Am
I'm thinking maybe the EGR valve.
Old Jun 23, 2021 | 03:32 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
The egr will only open off idle. If it were malfunctioning qnd suck open, the engine would be doing the opposite and only run at speed. The car would not idle at all. Weak coil perhaps?
Old Jun 23, 2021 | 08:36 PM
Car: 87 Trans Am
Thanks for the info on the EGR, one less thing to replace. The coil is new along with cap rotor and ICM. If I can get her out of the garage it's going to the shop.
Old Jun 23, 2021 | 10:06 PM
goldandblue's Avatar
Car: 1988 GTA
So i had a friend with an early 90s gmc jimmy. Very similar situation. Ended up his cat was stopped up.
Old Jun 24, 2021 | 07:15 AM
Car: 87 Trans Am
I'll pull the darn thing and see what happens. Thanks
Old Jul 22, 2021 | 05:36 PM
ascamaro's Avatar
I pulled the cat and the problem still exists.
Car starts right up and idles fine. Opening the throttle the RPM's drops off and the engine surges. Feathering the throttle I can get the engine up to 3000 RPM, but opening anymore will cause the engine to surge and drop off. I can drive the car slowly by playing with the throttle. The Fuel Pump and Fuel Filter are both new, along with all the Injectors. I have changed the Fuel Pressure Regulator, the pressure at the fuel rail is between 45 and 50 psi. The Mass Air Flow and Throttle Position Sensors are both new. I have changed the Distributor Cap, Rotor and ICM along with the Coil, Spark Plugs and Wires. I have no trouble codes.
I am at a loss as to what to do next.
Old Jul 22, 2021 | 06:09 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Maybe invest in a scanner and try to get a live readout of what's going on. I use a portable bluetooth scanner from this guy http://www.1320electronics.com/ very helpful as well.
IROC AND ROLL
Mar 29, 2016 09:52 AM
Brycegibler
Jan 19, 2015 04:59 PM
blue iroc
Nov 22, 2013 11:28 AM
Charlz B.
May 5, 2010 01:26 AM
