Hey guys,
Wanted to know your thoughts if these fuel injectors that i bought are correct and won't require any tuning. I didn't know some were different than others until some responses i got in another post here. Let me know your thoughts please. The car is an 88 IROC with the 5.7 Motor. Any help is greatly appreciated. Link below.
ARA
https://www.ebay.com/itm/28355781785...leKlSS&vxp=mtr
ARA
Not all of the part number is provided, they look like d3 with a adapter. I’d say they would need to be tuned might want to look at Delphi’s unless you want to tune.
Komet
close
- Join DateFeb 2021
- LocationWA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car1989 IROC-Z
- EngineL98 350 TPI
- Transmission700R4
- Axle/GearsBW 9 Bolt / 2.77 Posi
- Liked:453 Times in 339 Posts
Get the Delphi units from Southbay, they're plug and play.
GeneralDisorder
close
Garbage.
No data provided.
Get the Delphi's.
With injectors - you get AT MOST what you pay for. And if you aren't tuning you need EXACT replacements - which those are not. And they are useless for "tuning" as there's no characterization data provided.
#1 rule of tuning: Give the engine what it wants
#2 rule of tuning: Buy injectors with data.
GD
No data provided.
Get the Delphi's.
GD
I’ve had eBay d3 look alike provide offsets to customers. Still won’t tune.words to live by you do get what you pay for.
chazman
close
- Join DateDec 2001
- LocationChicagoland
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car1989 IROC-Z. Original owner
- EngineLB9. Dual Cats. Big Cam
- TransmissionWorld Class T-5
- Axle/GearsBW 3.45
- Liked:644 Times in 450 Posts
Are the new Delphis just as terrible as the original failure prone Multecs or are they an improved design?
No improved, I think the multec issue was winding coating failure.
Quote:
No data provided.
Get the Delphi's.
GD
you have that backwards, you can't give it what it wants without the data, either pay for it or the long drawn out process of discovering it for yourself through hours of messing around. Injectors aren't that expensive in the scheme of things now days. Amazes me guys don't just pony up the cash for an injector set that is of a known quality. Even if it's a stock car. Standard motor products and others make direct replacement injectors for them. Originally Posted by GeneralDisorder
Garbage.No data provided.
Get the Delphi's.
GD
