Tpi swapped no fuel pump or ses light
Hey guys I have a 1991 camaro rs 5.0l. The wiring was shot inside and out so I went ahead and did the tpi speed density swap.
I got a dash board and interior harness from a 1991 camaro v6. Also got the complete engine, wiring and computer from a friends 1991 z28. I have everything hooked up right and yet when I turn the key on, the service engine soon light does not come on and the fuel pump doesn't prime. I checked the fuel pump fuse and it was fine. Checked all grounds and they were good. But I have no power at the fuse at all. Also when I hook the battery up the brake lights come on. Ive put several different switches on it and they were adjusted properly. Can anyone help me figure this out?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tpi swapped no fuel pump or ses light
Engine: Lb9
Transmission: M20
Verified the pump fuse has power ?
