KNOCK SENSOR-1989 FORMULA 350
I have a 1989 Formula 350 TPI. Check engine light shows code 43. Bought 3 different knock sensors. Still have code 43. After looking at several forum posts, I see there are 2 different sensors, a 3.9K ohm and a 100K ohm sensor. All 3 I purchased were 100K ohm. For test purposes, I installed a 3.9K resister in place of the knock sensor and code went away and SES light turned off. I cannot figure out how to order the correct knock sensor The last two I ordered were one for a 350 and the other one was for a 305, both were 100K.. Does anyone have the part number for a 3.9K knock sensor? Thanks This car is kicking my butt.
Car: 1990 Pontiac Firebird Formula
Engine: L31 350 TPI
Transmission: Tremec TKX
Axle/Gears: 3.23 Posi
Re: KNOCK SENSOR-1989 FORMULA 350
FWIW, this is what I installed when I converted from 305 to 350: ACDELCO 21392
This 3.9k sensor works perfectly in my 90 speed density TPI, though your 89 probably has an external knock filter which would call for a 100k sensor.
The 100K sensor definitely does not work. The code go away with the 3.9K resister in place. I'm sure the 3.9 sensor will work. This car is so jacked up, there's no telling what's been done to this car. It has been an electrical nightmare !! Thanks
Car: 90 Formula / T-tops
Transmission: MD8
ya, looks like different years had different part number, someone needs to break out the parts book for you to confirm, but its all over the internet.
https://www.gmpartsgiant.com/oem-pon...ck_sensor.html
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Knock sensor wire goes to esc module on the bracket next to master cylinder.
the only devices near the master cylinder is the fuel pump relay and I think MAP sensor (small module with vacuum hose going to intake and one 3 wire plug) Would that be it ?
Engine: Lb9
Transmission: M20
What ecm do you have someone convert to a 1227730 ? No map on 89
Engine: Lb9
Transmission: M20
Are you sure your cars not a 90 ? The knock filter is part of the memcal. The ls
ks wires directly from ks to ecm. Could be a faulty ecm or connection at ecm have you followed the troubleshooting guide ?
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Engine: L31 350 TPI
Ok, Problem went away. I replaced the knock sensor with the 3.9K sensor and check engine light still came on. unplugged ECM and checked continuity from sensor to Pin F9 on ECM. Perfect there. Put everything back together and haven't had a problem since. Looks like maybe just reseating the connectors solved the problem ?? Thanks for all the help!!
