L98 Rebuild- Cam Questions
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
So after much thought, I decided to rebuild an L98 instead of buying an L31 crate motor and swapping the cam then spring issues and so on.
I will be using a AFR Enforcer heads, Accel/Lingenfelter intake, AS&M runners and a ported plenum.
I found a used engine to break down and found a local machine shop/builder.
The next dilemma is the cam again. Crower 00482LM is back ordered until mid-July. So I asked Summit their recommendation and they came up with Summit Pro SBC cam SUM-8801.
Crower 00482LM - $422 Dur @ .050” Lift: 213°/221° RR: 1.5/1.5 Gross Lift: .505”/.525” LSA: 114° RPM: 1900 to 5900 Redline: 6400
Summit 8801- $279 Dur @ .050” Lift: 212/218 RR: 1.5/1.5 Gross Lift: .525/520 LSA: 110 RPM: 1500-6000
1) Anyone with experience with Summit Pro SBC cams?
2) Any thought on the specs on the Summit vs Crower?
Thanks in advance!
Thanks in advance!
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: L98 Rebuild- Cam Questions
I'm sure someone will correct me if I'm wrong, but I was always under the impression that L98 heads didn't usually work with more than about .480 lift before coil bind without doing head work/swapping springs, retainers, etc. Seems like the same amount of work in the end.
Apologies, failed to add AFR Enforcer heads.
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Main difference I see between those cams is the LSA. If you are looking for something with a 114 LSA the Comp Cam 304-8 is pretty close to that with 210/220 duration and .51/.51 lift with a 114L
LSA.
LSA.
@spurgeon76 Is that cam a "step nosed" cam? I assume that is what I have to have for this L98 block. Another guy recommended Comp Cam 08-503-8 but it is also on back-order.
Car: 1989 IROC-Z
Engine: L98 350 TPI
I say order the Crower cam now and be ready to drop it in the day it arrives. Three months seems like a longish time until you're 19.584 'while I'm in theres' deep.
Thanks @Komet That is kind of where my head is. I don't need it today and the machinist just got the short block so it may be a few weeks anyway and all of them for a hydraulic roller are backordered.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Either will work. Imo could even go touch larger if something else was available sooner
I ran a 268/278, 218/228-110, .497/.502 (1.6 rockers) flat tappet in my old 1986 IROC with a 9.8:1, 355 with a ported TPI base and plenum and SLP runners. Ran pretty good with 24lb SVO injectors and a 1988 350 ePROM without any tuning other than increase base timing and adjustable fuel pressure regulator. It pulled right at 18" vacuum at 750rpm with a little bump to it. I ran a 3" exhaust with a Welded Dynomax dual 2.5" outlets and received a lot of comments on how it sounded.
The Summit 8802 Pro SBC hydraulic roller is close to what I ran, 267/275, 218/227-112, but with more lift. It might be a touch too much cam if you're planning on running the stock torque converter, but would be about perfect for a 2400 - 2800 stall speed converter.
https://www.summitracing.com/parts/sum-8802
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
The next dilemma is the cam again. Crower 00482 is back ordered until mid-July. So I asked Summit their recommendation and they came up with Summit Pro SBC cam SUM-8801.
Crower 09482 - $422 Dur @ .050” Lift: 213°/221° RR: 1.5/1.5 Gross Lift: .505”/.525” LSA: 114° RPM: 1900 to 5900 Redline: 6400
Thanks in advance!
Thanks in advance!
okay, nvm, i see the reference to 00482 above it.
Apologies, I did not see there was a “9” in there. It is a Crower 00482LM.
