87 iroc 5.7 idle issues
Old Aug 20, 2023 | 06:25 PM
  #51
Chaddyboy's Avatar
Re: 87 iroc 5.7 idle issues
Originally Posted by Airwolfe
I've used the code several times to get the Delphi injectors and other things from SouthBay. Sometimes they have problems with the website. A call to them should fix things.
did youbget the clips with the new Delphis?
Old Aug 20, 2023 | 06:35 PM
  #52
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Clips are not usually included
Borg-Warner #28417
AC Delco #17111267
GP-Sorensen #800-9417
Summit #MSD-2110
Old Aug 20, 2023 | 06:37 PM
  #53
Chaddyboy's Avatar
oh and why delphis and not southbay brand 200 bucks cheaper?
Old Aug 20, 2023 | 06:40 PM
  #54
Engine: Lb9
Transmission: M20
D3s seem rather noisy and run lean without battery voltage offsets applied to the tune .
Old Aug 20, 2023 | 06:45 PM
  #55
Chaddyboy's Avatar
so southdays require tuning but delphis don't straight plug n play?
Old Aug 20, 2023 | 07:00 PM
  #56
Engine: Lb9
Transmission: M20
Southbay doesn’t require anything, just stating from experience they D3 seem lean if that’s the only engine modification.
Old Aug 20, 2023 | 07:10 PM
  #57
Chaddyboy's Avatar
I have no mods it's all stock
Old Aug 20, 2023 | 10:32 PM
  #58
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
One thing I found on mine with a lousy idle like you're describing was bad check valves on the AIR system. Not sure how that would affect the idle but after replacing all three of them it idles just like it should now. Might check those before spending big money on other stuff, should blow through one way and deadhead the other way.
Old Aug 21, 2023 | 04:30 AM
  #59
Chaddyboy's Avatar
where would be the location of check valves.one thing I notice is a sensor going into the block near a collant sensor.Seems the wire is broken off not sure w
hat it is.
Old Aug 21, 2023 | 08:29 AM
  #60
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
The check valves are as shown here, one on each side and a third at the rear of the engine on the passenger side. Need to back away from that sensor some and take another picture, about have to be a coolant sensor/switch for something. Temp gauge work on your car?
Old Aug 21, 2023 | 08:45 AM
  #61
Engine: Lb9
Transmission: M20
hat it is.
that’s a aftermarket gauge sender, that’s where the ninth injector timer switch should be .
Old Aug 21, 2023 | 08:52 AM
  #62
Chaddyboy's Avatar
Ninth injector timer ....does it look like a larger coolant sensor which actually does have a injector connector .It was off to the side just dangling.
Old Aug 21, 2023 | 09:04 AM
  #63
Engine: Lb9
Transmission: M20
Theses are in wrong orientation but the csi timer is the one with red arrow.
without it longer cold start cranking times unless the prom has been updated.
Old Aug 24, 2023 | 12:11 PM
  #64
Nutro's Avatar
https://www.thirdgen.org/forums/afte...romo-code.html judging by the thread, I'd think it would work.
I've been trying it, it doesn't work. I sent them an IM and they were supposed to email me a link to use the coupon and they never did and now don't reply to my IM's
Old Aug 24, 2023 | 12:19 PM
  #65
Chaddyboy's Avatar
I actually had to talk to a rep to get the discount
LeonardS
Aug 31, 2022 08:34 PM
87iz28383
Jun 12, 2012 08:13 PM
ironreaper87
Apr 10, 2012 07:21 PM
Chevy-Z
Sep 9, 2006 10:03 AM
87iroc350conn
May 9, 2006 04:37 AM
