Serpentine Belt Size Smop Pump Removal
Old Feb 14, 2024 | 11:03 AM
19875speed's Avatar
Car: 1989 Formula Firebird
Transmission: 5-speed
Axle/Gears: 3:45
I have an 89 Formula 305 TPI with AC. I want to remove the smog pump and heard I will need to replace the serpentine belt with a different size. Does anyone know what size or have a part # for the right belt? Thanks!
Old Feb 14, 2024 | 02:16 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Serpentine Belt Size Smop Pump Removal
Have you searched ? multiple posts on this ? Using a grooved or flat bypass pulley or without?
Old Feb 14, 2024 | 02:32 PM
19875speed's Avatar
Axle/Gears: 3:45
I want to do it without using a bypass pulley. I did a search and 2 different people were giving 2 different answers on the size of the belt. I just want to make sure I get the right one.
Old Feb 14, 2024 | 02:44 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
LOL... was thinking the same. I did mine over a decade ago using TGO... search function!
Old Feb 14, 2024 | 02:46 PM
Engine: Lb9
Transmission: M20
So if you have 2 different length how different ate they in length?
can always use a old belt and make a mark and measure it.
https://www.thirdgen.org/serpentine/
Old Feb 14, 2024 | 02:59 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Yes there are 2 different and it all depends on the Harmonic Balancer Pully size. Apparently GM used 2 different sizes through the years. I can't remember the belt sizes but IIRC its only 1" shorter than the original.
Old Feb 14, 2024 | 03:17 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Alright!
I'm going to try answering from memory and notes. Do your own due and diligence.
For an '89 LB9, the stock belt with A/C is 94.5in (example: Dayco 5060945). That is with OEM accessories with no underdrive pulleys or any other sort of hack.
The "by-pass" belt is 96.8" (example Dayco 5060968). It needs to be routed differently than OEM. Should not be to hard to find how with simple research on TGO... but see picture below.
FYI, with underdrive pulleys, Hypertech Power pulleys for example, you need 93.5in to by-pass.
1988 is different OEM set-up but same by pass belt
Good luck
Old Feb 14, 2024 | 03:23 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
Old Feb 14, 2024 | 03:29 PM
SbFormula's Avatar
Engine: LT1 6.2L
Axle/Gears: 3.91
https://www.thirdgen.org/forums/tpi/...ml#post5988617
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
96.5 IIRC
Old Apr 11, 2024 | 09:56 PM
RickJay's Avatar
Originally Posted by dmccain
96.5 IIRC
Hello, I am new to this forum and am looking for some info. I purchased a 1991 Z convertible last year and am in the process of eliminating the A.I.R. system. So far I've removed all the plumbing, just so I can access the sparkplugs. With the system being removed, what adjustments must I make in order to have the O2 sensor and ECM happy so as not to get a leaner signal to the injectors, now that the AIR tubes are removed from the exhaust manifolds and plugged?
Thanx
RJ
Old Apr 11, 2024 | 10:01 PM
Engine: Lb9
Transmission: M20
You might not notice a difference but it can be turned off in tuning to prevent the ecm from adding 1mv value to o2 reading.
Old Apr 15, 2024 | 09:13 PM
BlksIrocZ's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI L98
Transmission: 700R4 Auto.
On a 1988 Iroc Z 5.7L TPI the belt size is Dayco part # 935K6, (I used a Continental Brand equivalent to that part #) that is a 96.8" 6 rib belt, that is with removing the A.I.R pump and not putting a delete pump/pulley in (why would you add another device with a potential bearing that could fail/cause noise/create drag/cost more).
Factory routing remains the same, its quick and easy.
Old Apr 16, 2024 | 09:45 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You can always do the string trick.
Old Apr 16, 2024 | 09:22 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Pretty sure this is the belt I used, 88’ L98 with no AIR pump and no delete pulley. It’s been on for a few years with no problems.
Old Apr 16, 2024 | 09:24 PM
Engine: Lb9
Transmission: M20
Cool stickers
Old Apr 18, 2024 | 02:14 PM
Eightyninef's Avatar
Whatever was recommended here was a tad too short. I had to forced it on there with a screwdriver pry bar. Wish I had 1/4" longer.; But I am loving the way the car runs without the AIR pump, and I'm especially loving the spark plug access.
Engine bay is so much cleaner, and the computer doesn't know the difference.
Old Apr 21, 2024 | 11:21 AM
Engine: Lb9
Transmission: M20
when the air pump is commanded on the ecm adds to the o2 mv to compensate for the air going past the o2. The ecm does know
Old Apr 21, 2024 | 09:53 PM
My understanding is that the AIR is cold loop operation only. So it doesn't care what the o2mV says. and my car now runs great with the stock prom, no AIR.
blkcam
Mar 12, 2008 03:30 PM
Imthebriman
Feb 22, 2007 03:19 AM
Dex
Apr 14, 2002 03:08 PM
custm1992
Mar 29, 2002 06:02 PM
