Will stocker TPI intake sustain 400HP
Old Jan 31, 2002 | 12:12 PM
Torqomeo's Avatar
Does anyone know if it will, cause the mini-ram and SuperRam are too expensive for me. The base manifold and Runners won't be stock and would be a ported edelbrock/SLP combo.
Old Jan 31, 2002 | 07:33 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Not to steer you away from upgrading the TPI but have a look here and see if you would like to try or get info on the LT1 intake swap.
http://www.lt1intake.com
Old Feb 1, 2002 | 03:29 PM
Torqomeo's Avatar
Hmmm looks pretty tricky and i don't think id want to do it myself!! I have a question though. Do you reuse the fuel rails from the TPI or do you need LT1 fuel rails? It's something to think about though! and it looks cheaper then the mini-ram and i could say i have a 406sml blk LT1.
Old Feb 1, 2002 | 07:08 PM
Sauron91's Avatar
Hey, where is the mini ram available from?
Old Feb 1, 2002 | 07:30 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You use the LT1 fuel rails.
Old Feb 1, 2002 | 09:39 PM
69TPI383's Avatar
The Mini Ram is made by TPI Specialties. www.tpis.com
P.S. hold on to your shorts when you see how much they want for it. Then you have to buy the fuel rails, etc. About $1200
Old Feb 2, 2002 | 04:58 AM
Engine: 4.0L
That's why I started playing with LT1 intakes.
Old Feb 2, 2002 | 05:19 AM
Gta-Paladin's Avatar
John, i'd like someone to do a lt1/ miniram dyno comparison sometime soon..
Anyone have ANY infor on the Holly Stealthram?
There are 9 second TPI cars out there.. and of course they're modified.
Old Feb 2, 2002 | 07:55 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If you are talking about a dyno comparing the LT1 to a Miniram, I would bet that they would come out very close. I say this, even though I recently purchased a Miniram. (I had made the deal a year ago and purchased it before John had done his LT1 conversion).
FYI, some of the more sophisticated "computer dyno programs" which have specific intakes to chose from (more specific than Desktop Dyno 2000), actually spec the LT1 virtually identical to the Miniram. That's how close the two are.
Old Feb 2, 2002 | 09:58 AM
Thanks Glenn, by the way... I'm flying into Calgary tommorow So i'll be near all of you BC bums and Cascade cowards
Old Feb 2, 2002 | 01:30 PM
360Iroc's Avatar
to your question the tpi will handle 400
Old Feb 2, 2002 | 02:03 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes it will.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
