LOL, My cam in my TPI went right through the timing cover.
Old Feb 1, 2002 | 04:29 PM
vortech305's Avatar
Im really gonna lose it this time, The idiots in the machine shop didnt install a cam button to prevent it from moving foward. Since the rebuild was done about a year and half ago its no long on warranty, and as my friend in his shop was putting the piston in TDC and cranking the cam made a whisling sound and made a hole on the timing cover. Now i gotta take the damn motor out of the car, Check and see if i gotta replace new cam bearing,check and see if i gotta replace all lifters and the cam. The cam isnt exactly sticking out of the timing cover but it made a hole and is inside the motor. He only cranked it for about a second or 2. Could it still have made a hole in the timing cover if cranked for at least 4-5 seconds?? I REALLY WANNA GIVE UP AND THROW THE CAMARO AWAY, but i have no choice and gotta rebuild the motherlover. pray for me.
Old Feb 1, 2002 | 05:48 PM
tpi_roc's Avatar
Take it from me, prayer doesn't help.
I've replaced the original 305, with another, that i'm replacing now, this is over like a month period.....
GAH!
Old Feb 2, 2002 | 03:50 PM
vortech305's Avatar
i hear u im so destined to make this motor run mid 13' N/A that i have to get it done AGAIN. Hopefully everything is ok, the worst case senerio is that the Cam Bearings were nicked or that the roller lifters were bent, but i hope the roller cam is alright i spent close to $250.00 for that cam and hopefully it isnt damaged in any way.
Old Feb 3, 2002 | 08:54 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Praying can't hurt. I'll see what I can do talking to the guy upstairs.
Old Feb 3, 2002 | 09:07 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
What year is that block. If it is a stock roller, it should use a thrustplate to keep the cam from walking.
Old Feb 4, 2002 | 03:56 PM
vortech305's Avatar
i did use a thrust plate but when i tightened it i didnt use thread lock if that was required its an 87' block, When i tightend i only hand tighten it like an idiot now i have to replace some parts .
Old Feb 4, 2002 | 11:19 PM
Car: Damn
Engine: This
You shouldn't need threadlock on the thrust plate bolts, at least I've never used it and no problems.
So the bolts backed out?
Old Feb 5, 2002 | 11:00 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I hope you don't need thread lock on those bolts, they weren't extremely tight coming off so I just put 'em back like they came out on my cam swap I just finished. I think i'd rather wait and see if they back out then going through all the work to get the timing cover off and on again.
Old Feb 5, 2002 | 08:30 PM
GRENDLE's Avatar
trust me, use thread lock on everything accept rocker bolts,valve covers,oil pans, and timing covers. drilling broken bolts out of the motor is no fun.
Old Feb 6, 2002 | 11:52 AM
Ant87IROC's Avatar
Car: 87 IROC Z28
Transmission: TH700R4
Amen to that!
camaro71633
Sep 1, 2015 10:24 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
