are stock l98 heads 64cc
Old Feb 1, 2002 | 07:42 PM
1bad350's Avatar
are stock 1990 l98 heads 64 cc
Old Feb 1, 2002 | 07:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yes they are
Old Feb 2, 2002 | 08:30 AM
CORKVETTE1's Avatar
no i do not believe they are 64cc i have an 85 vette and a friend has a 86 steel head vette and both are plain jane 76cc heads i do not believe they started puting different motors together in the late 90s just for camaros the vette went 58cc in 86 and half but i believe the camaro kept the same heads and pistons. untill the lt1 came out
Old Feb 2, 2002 | 09:12 AM
Guest
Guest
Posts: n/a
All the L98's I've had apart have 64cc heads.
Old Feb 2, 2002 | 09:25 AM
Car: 1988 IROC-Z
i agree
Old Feb 2, 2002 | 11:13 AM
CORKVETTE1's Avatar
unless the corvette steels are different
Old Feb 2, 2002 | 12:07 PM
69TPI383's Avatar
CORKVETTE1 can you get some casting numbers? I've never cc'ed a head but everything I've read shows an '87 and up cast iron head (083) as 64cc. I know there are tolerances in the manufactoring process but I doubt it would be 12cc differance. What was the casting numbers for the pre 87 TPI?
Old Feb 2, 2002 | 12:48 PM
CORKVETTE1's Avatar
here is head casting numbers from 85 corvette and early 86 vette
462624
Old Feb 2, 2002 | 12:50 PM
CORKVETTE1's Avatar
maybe they went with different heads for cams and birds
Old Feb 2, 2002 | 01:25 PM
69TPI383's Avatar
They could have. I wonder if the higher compression was part of the way the newer engines upped the hp. I haven't been around enough TPI engines to really know. I wasn't doubting you....I was just going on the info that I had for my 87 & up heads. Hmmmm....makes ya wonder what the General was up to at times!
Old Feb 2, 2002 | 01:45 PM
CORKVETTE1's Avatar
same here i am just going by the info on the vette heads i thought they would be the same maybe not
Old Feb 2, 2002 | 01:47 PM
CORKVETTE1's Avatar
maybe i should be loking for 87 and up camaro heads and get some free compression
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
CRFred
Feb 7, 2016 11:39 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
anesthes
Aug 8, 2015 09:37 PM
