TPI running RICH
Old Feb 26, 2002 | 05:37 PM
dassimunda's Avatar
TPI running RICH
hey club~!... i have a 1989 trans am.. TPI , i'ev put on a flowmaster and a high flow catylitic converter , i'ev also put in a new oxygen sensor., replaced all spark plugs and wires. checked timing... changed oil ... but the car still runs rich... really RICH. before and even after all this i'ev done ... if anyone can help me figure out this problem .. it runs so rich i get about 11 miles a gallon... it's so rich i can smell the gas comming out of the exhaust when when i'm in the driver seat idleing at a stop light.
the exhaust has no leaks.
Old Feb 27, 2002 | 12:59 AM
nblanchard's Avatar
is your fuel pressure regulator plugged in? thats all i can think off.. unless your injectors are bad, or one is bad, it may be dumping fuel into the engine. to check the injectors, use a multimeter and check the resistance acros the two leads, withthe injector unplugged... should read aroun 16Volts
Old Feb 27, 2002 | 07:19 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I don't know how it even runs if it's that rich. I can pop off 15-18mpg and my car runs so rich that it keeps fouling plugs.
Old Feb 27, 2002 | 10:15 PM
385TPI's Avatar
TPI running Rich
Check your regulator first, I have seen regulators rupture and cause the same problems. Pull the vacume line off the regulator and shake it to see if any fuel spills out. If there is not any fuel in the line than next check the pressure, should be in the neighborhood of 43psi plus or minus a couple of pounds. Also check to make sure the vacume source to the regulator is working at an idle and not plugged up. Check this all out and see what you get, there is still other things to check but this should provide for a start.
Old Feb 27, 2002 | 10:21 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm with Jim85Iroc .... I get 19-20mpg easy and I'm running 24# injectors with a 22# constant in the chip. Running so rich I have to change the plugs with every oil change because they get fouled out so quickly.
Your fuel pressure regulator diaphragm has probably got a hole in it.
Old Feb 28, 2002 | 03:23 AM
Jza's Avatar
Jza
It definitely wouldn't hurt to check the TPS sensor as well. If it's reading too high (incorrectly, unplugged, etc.) it'll dump in lotsa fuel thinking it's at WOT.
Old Feb 28, 2002 | 07:42 AM
Jim85IROC's Avatar
26lbs on a 19lb chip for me.
Old Feb 28, 2002 | 01:28 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I'm running 24# on a 22# chip, and I'm running lean according to the BLMs. Explain that one.
Old Feb 28, 2002 | 02:57 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Wheres that?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
